Our article has been published!
A project log for A new high accuracy tilt sensor
This project aims to build a tilt sensor that is cheap, very accurate and has a wide measuring range (up to 360 degrees).
Aron MolnarAron Molnar 12/24/2016 at 21:511 Comment
Our article about the project has just been published in the Journal of Magnetism and Magnetic Materials!
Thank you for your support!
http://www.sciencedirect.com/science/article/pii/S0304885316322703
Lutetium wrote 07/02/2018 at 21:36 point
That is epic! Awesome work!
