BME280 Atmospheric Sensor
A project log for 4WD all terrain robot
This is ongoing project of the mobile robot that can move in a rough terrain
codersilvercodersilver 03/11/2017 at 15:140 Comments
Recently when I was looking for temperature sensor for my mobile robot i found very small and inexpensive module BME280. This tiny sensor is capable of measuring up to three physical quantities: temperature, humidity, pressure/altitude. Its operating temperature range is quite wide: -40C to 85C. It is very energy efficient sensor - it takes measurements at less than 1mA and in a sleep mode less than 1µA. The easiest way to connect this sensor to the Arduino is by using The I2C bus (you do not need a voltage converter as in the case of SPI). You just need to connect four wires:
BME280 Arduino Mega 2560
GNDGND
3.3V3.3V
SDASDA (20)
SCLSCL (21)
Measurement data can be stored on the micro SD card (you need to connect external micro SD card breakout to your Arduino Mega 2560). I prepared for you a simple program logging measurement data on the SD card.
Below you can see some charts of measurements taken with the BME280 sensor. The relative humidity can be measured in a range 0 - 100% RH and pressure 30 - 110 kPa.
