PROBLEMS
PROJECTS OBJECTIVES
HYPOTHESES
The project is divided into four stages:
PROCEDURE
Diameter of the flywheel is 140mm
Therefore the circumference of the flywheel (2πr) = 440 mm
To achieve this delay in spark timing, the TDI moved 9.77 mm in the direction which the flywheel rotates.
The workability and the efficiency of the generator was tested over a repeated 6 hours period, varying the load and the results are stated in Table 1
RESULTS
When the generator starts working, it starts charging the ionized water electrolytic cell which in turns now produces the hydrogen-oxygen gas fuel for its continuous running.
Similarly ethane/propane gases are produced through the thermal catalytic gases which power the generator. Only one of the gas production systems can be used at once.
Anode
OH- → OH + e-
OH + OH →H2O + O
O + O → O2
1 mole of oxygen is released at the anode.
Cathode
H+ + e- → H
H + H → H2
2 moles of hydrogen was produced at the anode.
Summary of Reactions
Cathodic half cell reaction
4H+ +4e- →2H2
Anode half cell reaction
4OH- → 2H2O + O2+ 4e-
Over all reaction
4H+ + 4OH- → 2H2+ 2H2O + O2
Merits over higher carbon content fuel
The engine has higher pulling power and runs smoother. Inside petrol/diesel engine, carbon deposits builds up, thereby reducing the engine efficiency. The only emission when only ionized water is used is water, hence no carbon content to affect the engine (Ganrot,2005), when waste oil was used, the carbon(ii) oxide emitted was significantly lower, hence engine performance is higher.
All the results were subjected to Analysis of Variance Test at α level of 0.05. (95% confidence level) and where significant differences exist, it was tested using Duncan Multiple Range Test.
Testing the Efficiency of the Generator
Table 1: Volume of Fuel Used at Zero Load
Hours of Usage
Volume of Petrol Used
Volume of Waste Oil Used
Volume of Ionized Water used (litres)
1
1.3
0.59
0.17
2
2.7
1.16
0.33
3
4.0
1.75
0.49
4
5.4
2.33
0.66
5
6.7
2.92
0.83
6
7.8a
3.5b
1.01c
Boldened/a, b, c indicates significant difference at α level 0.05
