Preliminary_Test_Code_05-24-2016.inoDon't get too excited, I just grabbed some stuff from the examples and shoved it into a single UGLY sketch. Again this is a copy from my other project, they are currently running in parallel tracks. there will come a time when the software will most assuredly branch because the projects have a very different theme. But this is test software after all for testing the new hardware (experiment PCB). So please deal with it until the branch or put something in the comment section.plain - 1.93 kB - 05/26/2016 at 00:30 |
Desktop_Cooler_1_Rev1-B3.fzzExperimental PCB for developing project. Uses Teensy3.1 or Teensy3.2. DO NOT USE TeensyLC, the I/O are not 5 volt tolerant.fzz - 95.56 kB - 05/24/2016 at 11:05 |
