Making a PCB at home
A project log for DC-10
My implementation of C10 decimal time clock
danjovicdanjovic 11/27/2016 at 15:090 Comments
I made this PCB at home using toner transfer. I definitely have to use a better paper than ordinary magazine sheets! Nevertheless the result is acceptable.
This board should be double side but there are few connections on the top layer then I decided to leave the vias undrilled and complete the circuit using enamel wire.
