Assembled Board
A project log for DC-10
My implementation of C10 decimal time clock
danjovicdanjovic 11/27/2016 at 15:490 Comments
Just finished assembling the board for DC-10.
The displays are mounted on sockets and the microcontroller as well as the current limiting resistors are mounted underneath.
The third display is mounted upside down so its decimal point together with the decimal point from the second display can form a colon ( ":" ).
The enamel wiring is placed instead of the top layer and the thin flat cable is connected to the programming pins of the pic.
