First Boards
A project log for LCIRIC - Low Cost Infrared Imaging Camera
A standalone, open-source thermal imager which can be built for under $50 in parts.
josh-langeJosh Lange • 05/16/2016 at 05:51•0 Comments
I added the GridEYE sensor footprint to another board I'm putting together for a customer. I just got the boards and the parts should arrive this week. This board uses the same CPU and LCD that I plan on using for this project. This will give me the opportunity to test the following things before making the final version of the boards:
I have also been doing some initial software prototyping using a dev board; I hope to have an update on that in the next couple of days.
