Fail! Hand wired prototype works once only!
A project log for Megsy? A homebrew Teensy 3++
Creating a double-sized Teensy 3 to allow easy access to the pins that aren't reachable on a breadboard.
tina-belmontTina Belmont 05/25/2016 at 09:080 Comments
My lovely hand wired prototype was finally being put to use when I realized that I needed to pry it from the breadboard to check some signals. But when I pried it out, the pins seemed to like the breadboard better than the proto circuit board I had soldered it to, and some decided to stay behind.
What a mess!
