Kick Tic Tac Toe
Practice penalties on wall, accurate your shot, shout out in the hall !
Do remember the first kick into the goal. It gives the feeling to the player that is something special. Yet the journey is not so straight. It is when players practice their shots that the confidence of netting the ball in to goal comes. Most often players practice taking shots on the goal with goalkeepers. Studies suggest that penalties that are placement directed are more successful because they target areas beyond goalkeeper's reach. There are studies that performances of experienced players do not change much with or with out goal keepers. Kick Tic Tac Toe is such a game where football(soccer) players take targeted shots on a goal divided in to 3x3 Tic Tac Toe grid and may either get trained in taking placements and power shots or compete with fellow players. The game of Tic Tac Toe is such that the players have to increase the level of accuracy of their shots to excel. The Kick Tic Tac Toe has the feature to individually train players upon their weak areas.
This Kicktictactoe game is a sensor based device. With a wall installation, we establish a VNC session between host and client machine. The sensors responds to the impact and score updating happens real time. You can play kick tic tac toe remotely.
Here is promo video of the project :
  • 9 × mpu6050 GYRO + ACCELEROMETER IC
  • 1 × Raspberry pi Single board computer
  • 1 × TCA9548A Switches and Multiplexers / Analog Switches and Multiplexers
  • 1
    Building frames
    Create the PVC pipe frames of the suitable dimensions.
  • 2
    Tie the cloth
    Use umbrella cloth for good vibrations
  • 3
    Attach the mpu6050
    Cut the wires.Solder the connectors. Attach the 9 mpu6050s.
View all 6 instructions
zakqwy wrote 04/02/2018 at 02:27 point
'kick tac toe' ?
