TOF Laser Scanner Assembled.
A project log for Micro Robots for Education
We aim to make multi-robot systems a viable way to introduce students to the delight that is robotics.
joshua-elsdonJoshua Elsdon 10/17/2017 at 10:571 Comment
An update on the progress of the robot 'hat'. This is a TOF laser sensor that can be plugged into the programming port of the robots. With a range of ~2m, this can scan a circle of ~4m with just a quick spin of the robot. Will be made on flex PCB to integrate a 90 degree bend. Probably the smallest PCB I have ever made.  Bring up on this board is not a priority, as there are core features that are still needed for the robot project, also debugging could be a pain, as these use up the debugging port. When you get used to the STM break point debugging, flashy LED debugging seems dreadfully inefficient.
deʃhipu wrote 10/17/2017 at 12:36 point
Especially since the library for those is pretty huge and complicated, it can take considerable work.
