Calibrating the ELP-USBFHD01M-L21 CMOS sensor
A project log for DAV 4 UV/VIS Spectrometer
Well, this is the next evolutionary step from when I first bought the Plab 2.5 spectrometer kit
david-h-haffner-srDavid H Haffner Sr 05/19/2016 at 09:590 Comments
Yesterday I had to take some time and re-calibrate my new CCD sensor, the easiest way to do this was using Fluorescein in two diferent types of buffer solutions and then comparing the results against a master reference, which is Fluorescein in Ethanol from the Oregon Medical Laser Center's data resource center.
