5mm LED holder
A project log for Internet of Things Microscope
We are updating the microscope using open source materials to make microscopy accessible globally
apollo-timbersApollo Timbers • 12/13/2018 at 21:38•0 Comments
I whipped up a design for a simple LED holder. Use a bright white 5mm LED. You can power it with two wires from the 5 volt rail. Make sure to use a appropriate size resistor for your LED. For a fancy version you can use the PWM I/O on the Pi or add a pot to adjust the brightness manually.
File is under 5mm_LED_holder v3
Enjoy!
Apollo
