JPEG Image - 2.09 MB - 07/31/2022 at 18:18
Preview
Download
JPEG Image - 1.90 MB - 07/31/2022 at 18:18
Preview
Download
JPEG Image - 2.16 MB - 07/31/2022 at 18:18
Preview
Download
JPEG Image - 1.66 MB - 07/31/2022 at 18:18
Preview
Download
Standard Tesselated Geometry - 29.57 kB - 12/13/2018 at 21:38
Download
Standard Tesselated Geometry - 677.43 kB - 12/12/2018 at 14:39
Download
Standard Tesselated Geometry - 603.01 kB - 12/12/2018 at 14:39
Download
Standard Tesselated Geometry - 235.63 kB - 12/12/2018 at 14:39
Download
Standard Tesselated Geometry - 89.14 kB - 12/12/2018 at 14:39
Download
Standard Tesselated Geometry - 238.27 kB - 12/12/2018 at 14:39
Download
Standard Tesselated Geometry - 54.57 kB - 12/12/2018 at 14:39
Download
Standard Tesselated Geometry - 112.19 kB - 12/12/2018 at 14:39
Download
Standard Tesselated Geometry - 84.85 kB - 12/12/2018 at 14:39
Download
fusion - 110.68 kB - 07/10/2016 at 23:05
Download
fusion - 123.80 kB - 07/10/2016 at 23:05
Download
fusion - 109.36 kB - 07/10/2016 at 23:05
Download
fusion - 30.63 kB - 07/10/2016 at 23:05
Download
fusion - 130.67 kB - 07/10/2016 at 23:05
Download
fusion - 96.68 kB - 07/10/2016 at 23:05
Download
fusion - 115.95 kB - 07/10/2016 at 23:05
Download
fusion - 44.87 kB - 07/10/2016 at 23:05
Download
Standard Tesselated Geometry - 149.69 kB - 07/10/2016 at 01:25
Download
Standard Tesselated Geometry - 83.09 kB - 07/10/2016 at 01:25
Download
AutoCAD DXF - 6.74 kB - 07/10/2016 at 01:25
Download
Slide Platform.stl
Also print solid, standard metal spring loaded slide holders fit well.
Standard Tesselated Geometry - 79.38 kB - 06/27/2016 at 20:32
Download
big gear 30 teeth.stl
Nice and big gear
Standard Tesselated Geometry - 915.11 kB - 06/27/2016 at 20:27
Download
small gear 10 teeth.stl
Has a small hole so you can drill out to fit your motor type
Standard Tesselated Geometry - 274.52 kB - 06/27/2016 at 20:27
Download
Refined camera mount bottom.stl
Optical element, print in black
Standard Tesselated Geometry - 236.70 kB - 06/27/2016 at 20:27
Download
Refined camera mount top.stl
Standard Tesselated Geometry - 86.41 kB - 06/27/2016 at 20:27
Download
160mm Tube part A.stl
The optical tube, print in black
Standard Tesselated Geometry - 267.66 kB - 06/27/2016 at 20:27
Download
Focus ring.stl
Where you tie the high test fishing line too.
Standard Tesselated Geometry - 80.84 kB - 06/27/2016 at 20:27
Download
Fancy knob.stl
It is a human to machine interaction device
Standard Tesselated Geometry - 246.57 kB - 06/27/2016 at 20:27
Download
Focus Mount.stl
It holds it all together and has holes that bearings fit into.
Standard Tesselated Geometry - 141.00 kB - 06/27/2016 at 20:27
Download
Focus axle.stl
A simple axle, print solid
Standard Tesselated Geometry - 79.87 kB - 06/27/2016 at 20:27
Download
160mm Tube part B.stl
Standard Tesselated Geometry - 147.54 kB - 06/27/2016 at 20:27
Download
Base plate.stl
This is a the fancy base that secures the scope and has holes to fill with rocks, ball bearings, or even crushed sea shells for weight.
Standard Tesselated Geometry - 17.27 kB - 06/27/2016 at 20:27
Download
motor_control.py
A updated control of the stepper for the Z axis with a added speed control variable
plain - 2.28 kB - 06/16/2016 at 22:47
Download
microscope base.stl
The fancy base
Standard Tesselated Geometry - 13.60 MB - 06/16/2016 at 22:41
Download
README.md
Basic information
md - 70.00 bytes - 04/29/2016 at 02:49
Download
