Glue and Endstoppers
A project log for A Rotary Dial, Stepper Actuated Safe w USSR Nixies
When you enter the correct code on the rotary dial a box will open and you can hide your stuff, with nixie dial feedback!
isaxiSax 04/06/2018 at 23:370 Comments
A few things happened today.
I installed end stoppers for the motor. They are the same kind you would find in a 3D printer (by makerbot),  There are two end stoppers, the open position one is barely visible. Here you can also see the stepper motor. It's an old variable reluctance stepper and can therefor be run with a darlington array from 24V.
Once the breakers were in place I glued the plate to the metal box using epoxy.
After crimping all the wires I made as tube socket replacements I glued the whole tube assembly as well. They are held in place by vulcanizing rubber to an aluminum rod.
