DSOXLAN_PLUS
3-in-1 DSOX Lan board for the DSOX 2k & 3k series scopes, includes LAN, USB-UART, & JTAG connections on card faceplace.
Homebrew DSOX Lan card for the DSOX 2k & 3k series scopes, using the current homebrew LAN board designs, but with added on functionality for USB-UART and full JTAG buffer, to utilize the internal RS232 and JTAG connectors on the scope main board. This allows you to have 3-in-1 functionality from the same board: 1) LAN 2) USB-UART 3) JTAG buffer The USB-UART gives a simple USB-B connector on the faceplace, which provides full acess to the RS232 connector on the scope main board. This is powered by an MCP2221 chip, which gets power from the host USB interface, so that you can have the serial port ready and open before the scope is even powered on. *** necessary in order to halt UBOOT at immediate scope power-on *** JTAG 10-pin male IDC connector for full JTAG functionality, which is connected from 10-pin header to the main board jtag header via IDC cable.
DSOXLanPlus_misc.zip
Extra images/JTAG setup, etc
Zip Archive - 1.78 MB - 04/03/2018 at 20:16
Download
Schematic (image file)
Portable Network Graphics (PNG) - 425.58 kB - 04/01/2018 at 20:26
Preview
DSOXLanPlus_BOM.xlsx
BILL OF MATERIALS
sheet - 107.06 kB - 04/01/2018 at 20:26
Download
DSOX_LanAdapter_EAGLE_PCB.zip
EAGLE Schematic/PCB Files
Zip Archive - 87.25 kB - 04/01/2018 at 20:25
Download
