Simple linear motor
A simple linear motor made from parts harvested from an old cd player, a motor and gearbox and some polyester resin.
PJKPJK
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A threaded bar with a high pitch was taken from an old cd / dvd player. After smearing it with grease it was inserted in to a small card box. Resin was then poured to the desired level. Once set, a bit of rotational persuasion and there you have it, a perfect nut for your thread. I think the pictures describe the rest. The travel time is of course a lot quicker than normal tight pitch thread bar. This project is part of an ongoing one.
