Autonomous Infinite 3D Printing: WorkHorse 3D
The WorkHorse 3D Printer gives anyone the power of a factory. A custom robotics module on the printer automatically ejects print jobs.
Abstract
3D printing has the potential to democratize manufacturing. However the capabilities of 3D printers are limited by requirement of human operation. The need of manual part removal prevents 3D printers from being used for mass production purposes. Therefore, the purpose of this project is to build a 3D printer that can print a constant stream of parts without user interaction. The finished machine is capable of independently ejecting and starting print jobs. The WorkHorse 3D Printer allows any small business, organization, and person to leverage the power of a factory.
[Figure 1: Demo of WorkHorse 3D Printer]
The Problem
Even though 3D printing is a newly emerging technology, it has rapidly became mainstream in education, manufacturing and many other industries. 3D printers allow anyone to easily produce complex parts.
However, these machines have one critical flaw. After a 3D printer has finished printing a part, a person must physically go to the printer and remove the part from the print bed. A 3D printer cannot start its next print job, until the previous part is removed. This constraint cripples the productivity of 3D printers. If 3D printers could automatically eject their printjobs, then they could print out a constant stream of parts. The efficiency of the machine would drastically increase.
Many businesses already use 3D printers to manufacture product. Currently, their manufacturing capabilities are constrained by the constant need to manually remove/start print jobs If this task was automated, it would be easier for more companies to use 3D printing for volume manufacturing.
Personally, I work in a 3D printing lab that prints hundreds of parts for my fellow university students. From my position, it is obvious that this constraint significantly limits the number of print jobs our lab can complete per day.
[Figure 2: Problem Pitch Video]
The Solution
The purpose of this project is to build a fully automated 3D Printer: The WorkHorse 3D Printer. The WorkHorse 3D Printer has a conveyor belt module that autonomously ejects finished print jobs from the printer. With this novel feature, the WorkHorse 3D Printer is able to print a constant stream of print jobs without human intervention. This is a breakthrough for the 3D printing industry. Automatic part ejection will improve the functionality and capability of 3D printers. Within the next few years, autonomous part ejectors will be as ubiquitous to 3D printers as paper ejectors are to paper printers.
Build Hope
Over the past few years, people around the world have been empowered by rapid prototyping. Affordable CNC machines, allow anyone to easily put together a prototype. All of the cool hardware recently developed by makers, students, and startups is only possible because of easy access to these powerful machines. However, mass production still remain out of the reach of most people. Currently, makers can only mass produce by placing an order in an overseas factory. This process is expensive, time consuming and prone to error.
Building an affordable automatic 3D printer will open up whole new doors to hackers. An automatic 3D printer will allow any to wield the power of a factory. Once automatic 3D printers become mainstream, conveyor belt lines will not be exclusive to large companies. The technology will truly be democratized. Providing this tool to DIY enthusiasts will once again allow them to make amazing things.
It will be more feasible for tinkerers to transition from an idea to a bustling company. It will be easier for libraries, schools, and other organization to offer 3D printing services.
It will ensure that making once again reaches new heights.
Modularity
I want hackers to easily be able to add this hack to their 3D printers. I am excited by the idea of makers setting up small scale factories. Making this technology easily accessible will lead to an explosion of what people can make with their 3D printers.
Therefore, the robotic ejection module is designed to be easily integratable with other...
  • Testing Automatic Ejection
    Swaleh Owais05/29/2018 at 01:11 0 comments
    [3D Printer Automatically Ejecting Print Job]
  • Test Print with WorkHorse 3D Printer Mk. 3
    Swaleh Owais05/25/2018 at 05:18 0 comments
    I have managed to print quite a few parts with the integrated conveyor belt. Next up, I'll tinker with the infinite build capabilities.
  • Ejecting Parts from WorkHorse 3D Printer Mk. 3
    Swaleh Owais05/23/2018 at 05:51 0 comments
    I have finished making the belt of the WorkHorse 3D Printer and I ran a few quick 3D printing tests.
    I need to make multiple adjustments to the firmware to finalize the machine. For example, the y axis movement is not proportional. The printed object should be circular.
    I would also like to give  a shoutout to the Deltesian project. The Deltesian is an open source 3D printer designed by a crew of extremely knowledgeable and friendly hackers. I've spent a lot of time communicating with the team on advice and queries about 3D printing.
    https://github.com/bornity/deltesian-part-files
  • WorkHorse 3D Printer Mk. 3: Mechanical Construction
    Swaleh Owais05/17/2018 at 01:24 0 comments
    I have finished building most of the WorkHorse 3D Printer.
    I have a solid frame to test this design with. The last major component to build is the belt.
    The next steps involve me making new firmware for the 3D Printer and then testing:)
  • CAD of WorkHorse 3D Printer Mk 3
    Swaleh Owais04/28/2018 at 17:39 0 comments
    I have finished a rough CAD mock up of my third prototype autonomous 3D printer.
    [Figure 1: WorkHorse 3D Printer Mk. 3 Rough CAD]
    The printer features a hybrid delta-conveyor belt design. The linkage system provides the X and Z Axes movement and the Conveyor Belt provides the Y Axes movement. The design change greatly reduces the complexity of the mechanism.
    I plan to allow the printer to print at an angle to provide infinite build volume functionality.
    A common aspiration of open source 3D printers is to be able to print all the components required for a printer. This allows the machine to be self replicating. With the new prototype 3D printer, hackers will finally be able to print long structural extrusion pieces.
    Image result for long aluminium extrusion[Figure 2: Prototype Should be Able to Print Structural Pieces as Seen Above]
    References
    [2]RoverCNC. (2017). V-Rail Aluminium. Barrier, Ontario. [Electronic]. Available: www.rovercnc.com/
  • Revisions for WorkHorse 3D Printer Mk3
    Swaleh Owais04/24/2018 at 20:43 0 comments
    I am currently developing a third iteration of the WorkHorse 3D Printer.
    In this revision, I am placing a special emphasis on building an industry grade machine. NO MORE DUCT TAPE! I am still working on the new design, but I am quite happy with how I simplified many of the components.
    To pay for the high quality machine, I am hoping to be able to use the Hackaday Funding.
    So if I am lucky enough to have a judge read this post, I implore them to consider the below details while selecting the top 20 candidates.
    • Is this a unique solution to a particular challenge facing the world today?
      • 3D Printers have the potential to democratize manufacturing. Currently, mass production technology is only within the reach of large factories and businesses. Most hackers/makers lack the financial means and technological aptitude to use automation machinery. 3D printers are inexpensive and easy to use. Providing 3D printers with the ability to automatically eject/start print jobs would allow anyone to setup a small scale factory. Empowering tinkerers with this ability is sure to generate exciting and innovative hacks.
    • How thoroughly documented were the design process & design decisions?
      • I understand that this project is more likely to succeed with the help of the hacker community. Therefore, I am being completely transparent during project development. I am posting all notes, designs, and software online so that others can critique and improve my work.
    • How easily can this design be implemented by other people in future projects?
      • The project is completely open source. This will make it easy for others to incorporate my automatic print job ejection mechanism into other 3D printers. Furthermore, I am committed to making my automatic print job ejection mechanism into a single modular unit that can be easily attached to any 3D printer.
    • How complete is the project?
      • At this point, I have completed two successful prototypes of the WorkHorse 3D Printer and a robust software application. Both prototypes were able eject a consistent stream of print jobs automatically. My software application provides users with a simple interface to send print jobs to the printer. By my no means is this project complete, but I am satisfied by my progress to date. I strongly believe that my next prototype will exhibit the drastic usefulness of automatic 3D print job ejectors. Being a university engineering student, I do not have the largest budget to spend on this project. I am hoping to use the Hackaday Prize money to pay for expenses. I would know exactly how to spend the prize money, since I already have a refined parts list for building Mk. 3.
    Also, I would like to thank everyone that liked my Hackaday entry for helping support this project.
    During the robotics module contest, I will attempt to turn my mechanism into an independent module.
    My next post will be on the CAD and design changes for Mk. 3.
  • Mass Production Test with Y-Axis Conveyor Belt
    Swaleh Owais04/15/2018 at 01:44 0 comments
         I printed a queue of parts on my integrated conveyor. The parts all printed and ejected successfully, but there were still some issues.
    [Figure 1: Printing Queue of Jobs with 3D Printer]
        I am currently printing on a roll of duct tape. While the print surface is fine, duct tape cannot withstand the high temperature of the nozzle. If the hot end touches the duct tape, the tape melts and fuses with the extruded plastic. This adhesion makes it more difficult for the part to be ejected later on.
    [Figure 2: Duct Tape Belt Damaged by Hot End]
        I plan on replacing the belt with a stainless steel shim.
  • Using Conveyor Belt as Y-Axis
    Swaleh Owais04/13/2018 at 06:53 0 comments
    I am now focused on simplifyng the design of the printer.
    I have moved from a Delta Design to a Cartesian Design. I am using the motion of the conveyor belt as the y axis. This design change reduces the number of motors needed for the mechanism.
    [Figure 1: Integrating Conveyor Belt Demo]
  • Revisions and Improvements for WorkHorse 3D Printer Mk. 2
    Swaleh Owais04/08/2018 at 02:09 0 comments
    I am now working on the second iteration of the WorkHorse 3D Printer. The new prototype will have several fundamental changes that should greatly improve the effectiveness of the design.
    I will be switching from a Delta design to a Cartesian design. I will replace the y axis linear actuator with a conveyor belt. The conveyor belt will be controlled by stepper motors that will provide y movement. This modification will simplify the design and reduce the number of separate mechanisms.
    Additionally, I will improve the software application and provide a G-code tool path viewer to users. I will also add a widget that allows users to send single lines of G-code through the interface.
  • Print Test with Software Application
    Swaleh Owais04/08/2018 at 02:01 0 comments
    I have ran my first test prints with the software application. The application successfully completed several print jobs autonomously.
    [Figure 1: Print Queue Test with Software Application]
View all 25 project logs
lukewebdev wrote 06/14/2018 at 04:29 point
Would love to help test/prototype this on a prusa i3 type printer I have.
lahav svorai wrote 06/09/2018 at 14:57 point
Hey,
Love the project!
can you please write me a links for the several belts you have been used?
can you tell me what material did you use one the belt?
I would like to try it my self!
Swaleh Owais wrote 06/12/2018 at 19:07 point
Thanks!
I ended up making custom belts. The logs detail the process.
Sergey Osaulenko wrote 06/08/2018 at 22:52 point
hi
If it possible, on your rules I want to come to your project and start working on it. I have some skills for making 3d printers. Hope for your positive respond
Swaleh Owais wrote 06/12/2018 at 19:09 point
Hey!
This is a community driven project and I would love collaborating with others to develop it!
I sent you a PM.
bencooper96 wrote 06/08/2018 at 19:01 point
Is there a BoM or any stl/cad files? I'm having trouble finding them.
This looks like a really interesting project nice work!
Swaleh Owais wrote 06/11/2018 at 16:52 point
Hi, I'm making a fourth prototype right now and I'll post CAD files for it soon.
Just need to finish my exams first though, which will take a couple of more weeks :)
And thanks!
bencooper96 wrote 06/11/2018 at 17:01 point
Sounds good. Thanks! Good luck on your tests!
justinrox123 wrote 05/11/2018 at 19:36 point
Amazing project! I love it, the industry really needs this type of automation, I strongly believe it will propel the 3D printing industry forward!
whoismezero wrote 05/11/2018 at 18:14 point
What did you use as the conveyor belt on the Mk 2?
sulaiman wrote 04/26/2018 at 01:00 point
Wow, this project seems very interesting.
I know someone who uses 3D printers a lot and this type of device seems like it would be very useful to them, since it would help them by loading multiple files at a time and having them print one after another without addition input; just like a regular printer!
Cant wait to see this in the future.
Swaleh Owais wrote 04/26/2018 at 01:17 point
Thanks!
mmiscool wrote 04/25/2018 at 21:40 point
Is this not patented by stratasys
https://patents.google.com/patent/US8668859B2/en
Swaleh Owais wrote 04/25/2018 at 23:15 point
My first prototype probably falls within the scope of the MakerBot patent. Although, I would assert a key difference between the two is that my prototype works consistently ;). When I was making the first prototype, my focus was just to determine the optimal drum radius.
However, in my second and third prototypes the conveyor belt is the y-axis which moves it out of the scope of the patent. Also, the third prototype prints at an angle.
Moreover, I am determined to make sure that this project is completely opensource. I want to fully document the automatic ejection module, so that any hacker could incorporate that functionality into her/his printer. Because you can do so many more things with a 3D printer that operates independently :).
BTW, I think your Autodrop3D project is pretty neat!
Also BTW, I'm Canadian and everyone I've built this system for is Canadian too. This ensures that I am in no way violating the rules concerning patents outlined in the Hackaday Prize Ruleset.
mmiscool wrote 04/30/2018 at 04:30 point
Would you be interested in testing your printer with the autodrop3d system. We have a server up and running and it would be fun to hook another printer to it. All that would be required is a raspberry pi.
Reagan Susanto wrote 04/22/2018 at 14:42 point
This is great. Do you have any reason why the conveyor belt needed to be in that length?
Swaleh Owais wrote 04/23/2018 at 03:23 point
Thanks a lot!
There's no particular need for the conveyor belt to be that long.
On Mk 3, I plan on reducing the conveyor belt length to 18 inches.
