I have built a simple Delta 3D printer. The printer has a simple Kossel design. This printer has a large z-axis of 300 mm ensuring adequate room to fit a conveyor belt. I have printed test parts to check whether the print quality decreases after I add the conveyor belt.
[Figure 1: Delta Kossel 3D Printer]
[Figure 2: Delta Kossel 3D Printer Closeup]
[Figure 3: Test Print 1]
[Figure 3: Test Print 2]
