EVBox|CAN: Protocol
A project log for The EV Box
An open-source electric vehicle instrumentation system.
nealNeal 06/11/2016 at 18:200 Comments
Summary:
This log will contain the basic communication data format for the EV box system. It will be updated as needed.
TODO: Make this a page on github as well to track changes as they will affect code revisions
TODO: Create message ID groups to standardize priority
TODO: Decide and list the default baud rate (bandwidth calculations needed)
CAN BUS
Data Field Standard
CAN bus data field format. All units are in SI-base and SI-derived format with conversions done at the display level.
Rules:
Monitoring Data
This data is sent from nodes and includes voltage, amperage, speed, and temperature information.
Data FieldDescription
999.9KPHSpeed
9999.99CTemperature
99999RPMRPM
999.999VVoltage
9999.99AAmperage
999.99KWPower
999.9KWHEnergy
999.99AHElectric charge
HH:MM:SSTime (24h)
MM-DD-YYDate
999.99KGMass
Control Data
Message ID
Lowest numbered ID gets the highest priority message
Rules:
Message ID GroupDescription
0x100DisplayBox, BrainBox
0x200TachBox
0x300
AmpBox, VoltBox
0x400
0x500
