Free 3D Milling Software: CNFR33D
This project is the development of free, user friendly software for 3D milling on DIY CNC machines.
The software I am developing will allow a user to load in a 3d file and select their settings and the program will build G-Code to mill the item. The idea is to have a milling equivalent to free 3D printing software like Cura which is easy to understand and use. It is currently being developed to work with 3D printer electronics using the Marlin firmware.
TheotherMike wrote 04/29/2016 at 22:31 point
Interesting, how many axis do you want to integrate??
3 axis is common stuff, 4 would be great and 5 would be a total novelty !!
fabian wrote 05/31/2018 at 18:59 point
4 axis for example A in not necessary 360 sometime need 30-40 degree
TheotherMike wrote 06/01/2018 at 07:34 point
Excuse me, I do not fully understand! Do you mean, in most cases 3 axis is enough and only sometimes it´s enough to tilt the workpiece by 30-40° ?..?
