A very stable reference frequency generator is required now that I must calibrate the 18KHz and 32768Hz clocks (#Yet Another (Discrete) Clock and #Clockwork germanium). I also want to drive my #Quick & Dirty Frequency Generator
I have found many useful resources on the 'net but this particular model has interesting resources scattered around websites. Furthermore, my experiments found other useful signals.
Other Rb projects on HaD:
- GPS Disciplined xCXO
- GPS locked 10MHz lab frequency reference
- GPS+Atomic clock build
- 10MHz Rubidium Standard
Pinout of the HD15 connector:
- +15Vcc (2A peak at power-on, slowly decreases to 0.6A when warm, it is recommended to use abundant filtering to prevent HF from the PSU to interfere with the output frequency)
- GND
- +5V (marked "optional" but no jumper. This model generates 5V inside with a buck regulator. I found and shorted the right pads to provide this power to the outside, to power minimal circuits)
- GND
- 10MHz output (only output a few seconds after reset, then unavailable. Can be reused for other purposes if it is rewired on the PCB at the CPLD's output)
- "Spare" (no idea what it is)
- GND
- "Analog tuning / optional" (not used)
- "Reserved / Factory test output" (not used)
- GND
- 1PPS output (LVTTL, 10µs pulse, optional, valid when locked)
- Lock (open collector output)
- Reset input (LVTTL Active high)
- Serial data in (LVTTL) (not tested, not sure it is implemented, not found by others to respond to known protocols)
- Serial data out (LVTTL) (not tested, high level found so it's implemented but no idea of what protocol it is)
Logs:
1. Links and resources
2. Providing the internal 5V on the HD15 connector
3. Where to get some interesting frequencies ?
4. Lock achieved
5. Ups and downs
Yann Guidon / YGDES
So far, so good and I've found the 20MHz as expected.
Pero
Christoph
Bud Bennett
