Automated Living Backend Server
This is the sub-project for Automated Living: This is the server backend component
I originally was going to have 1 server be responsible for the OpenCV, TFTP, NFS, and Notification server, but I have since split the responsibilities.
All parts of the project can be found by clicking here:
https://hackaday.io/projects?tag=JAW.HA
  • Packages and IP setup
    James Wynhoff04/26/2018 at 23:29 0 comments
    apt-get install xinetd tftpd tftp
    and in  /etc/network/interfaces :
    auto enp3s0:1
    iface enp3s0:1 inet static
    name TFTP Server
    address 172.16.0.251
    netmask 255.255.255.0
    broadcast 172.16.0.255
    network 172.16.0.0
    and then
    /etc/init.d/networking restart
    ifconfig
    enp3s0    Link encap:Ethernet  HWaddr d4:3d:7e:ba:a9:56
              inet addr:10.0.1.74  Bcast:10.0.1.255  Mask:255.255.255.0
              inet6 addr: fe80::d63d:7eff:feba:a956/64 Scope:Link
              UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
              RX packets:433088 errors:0 dropped:0 overruns:0 frame:0
              TX packets:11424 errors:0 dropped:0 overruns:0 carrier:0
              collisions:0 txqueuelen:1000
              RX bytes:66214575 (66.2 MB)  TX bytes:1114489 (1.1 MB)
              Interrupt:19
    enp3s0:1  Link encap:Ethernet  HWaddr d4:3d:7e:ba:a9:56
              inet addr:172.16.0.251  Bcast:172.16.0.255  Mask:255.255.255.0
              Interrupt:19
    Sweet, up and running!
    next I will configure the services!
  • Really MSI?
    James Wynhoff04/04/2018 at 20:57 0 comments
    I just recently got my office in a (mostly) usable state at the new house, and threw my hand usb installer into the PC I was going to use as a server with a fresh 3tb sata drive, I came back to it today and found things were a hot steaming mess, the scripts I have on my auto installer relies heavily on having an internet connection, this was actually the first time I have had a problem with this, I should make everything fail gracefully, it doesn't, it turns it into a hot mess.
    Right away I found the problem, the integrated NIC is putting on a good show, but its all for show.
    It gets a link light, you can detect the interface, but it wont DHCP, and wont respond to static settings, I booted a LiveUSB to confirm it wasnt just an issue with this install, no dice.
    Maybe now I remember why this PC landed in the reuse pile.....
    I know somewhere in this house exists a PCI-E NIC, I just saw it...... a few weeks ago?
    Oh boy..
  • It all starts with an ISO...
    James Wynhoff04/02/2018 at 22:14 0 comments
    Today I will be working on getting the first server set up, I will post its specs here as soon as I figure out what machine I will use...
    Its roles will be:
    TFTP Server (boot SBCs)
    Central Log server
    Notification server (using prowl to send messages to the phones)
    Video Transcoding (lowest priority)
    HDMI framegrabber (more details soon)
    It will have a virtual interface sitting at 172.16.0.251 for TFTP serving so I can hard encode the address in uboot and let this be as easy to deploy as possible without interfering with standard network setups.
    The base will be Ubuntu 16 Server
View all 3 project logs
