The First test of Squid in a robotics application.
A project log for The Squid! Open robotics control module.
The Squid! Open robotics control module. Bluetooth, I2C or Serial interfaced for easy Human to Machine or Machine to Machine interface.
dennisDennis 06/04/2018 at 02:400 Comments
Here’s the first test of Squid in a robotics application. Although Squid is designed to be controlled by an external controller such as a Raspberry Pi, Squid can also operate in a standalone mode.  In this video, Squid is controlling a simple insect-like robot using layered behaviors. With a lot of onboard resources, I can think of a lot of add ons I might add to the robot. I have additional updates I want to add like I2C and analog to digital conversion, but with the first operational Squid, I wanted to jump ahead a bit and place Squid on a robot. Below are a couple of pictures of the bot with Squid as its controller. The robot can now also very easily be controlled through a Bluetooth connection.
