In principle it works, but I failed...
A project log for Yet another laser engraver / cutter 2
I improved the mechanics on my first laser plotter to get a more accurate machine to make PCBs with it.
dechemistdechemist 08/15/2016 at 08:010 Comments
Sorry for the long delay, I was busy and had no time to write a blog entry.
As a test I used a schematic for an FTDI Serial to USB adapter I found online. It has very small dimensions (1.9 x 3.5 cm) and a SSOP28 footprint on it with 0.5 mm pin pitch.
The first try was already ok, but not really usable since some of the very small pads were to small due to some inaccuracy.
The second try look better but it was still not usable.
With these results in hand I realized that my laser plotter is simply not made for such small structures.
Nevertheless I tried to make bigger PCBs with it. I choose the layout of one of my current projects, converted it to DXF and gave it a try.
In general the PCB looks quite ok, but that's it. If one looks closer some of the diagonal tracks are uneven and smaller as they are supposed to.
I gave it a last try with another layout and this one is the best so far. The tracks have the correct width and are not broken.
A drilled a view holes and tried to solder some of the parts, mainly resistors and connectors. As you can see on the pictures the joints are not very pretty, although I would say of myself that I can solder quite ok. The main problem was the heat dissipation: My 80 W soldering station with a needle tip (400 °C) could not heat up the pad high enough to get the solder to flow nicely. The second problem was the 0.1 mm etched gap between the pad and the rest of the PCB. It was very difficult not to connect these two. The solder would just flow over the gap. Maybe the last problem might be fixed by applying a solder stop coating.
Conclusion
My laser plotter is not made for such small structures. As I understand the situation, it is to big and thereby to inaccurate since small inaccuracies sum up and result in 0.5 mm deviation. For fun projects where accuracy of > 1 mm is not needed like engraving in wood, cardboard or cutting felt and foam it is just fine.
Problems that have to be fixed
- To small tracks: One should use the tools correction parameters in GCODE (G40/G41/G43) to get the correct track width. The laser beam was focused to about 0.1 mm. Unfortunately GRBL 0.9j does not support these. Maybe these can be hardcoded in the GCODE / DXF file with software.
- Inaccurate tracks: My guess is, that this particular problem only can be fixed by building a smaller plotter. If one would build a plotter lets say in a DIN A4 (210 x 290 mm) format the small inaccuracies would not sum up as bad as in my 400 x 550 mm machine.
Laser power and PCB etching
Just a quick overview over the settings and materials I used for testing
- Laser: 405 nm laser diode, 100 mW max power. In GCODE I used the paramter S=5, which relates to about 5 mW laser power. Output powers up to 20 mW worked fine, but you have to set a higher feed rate.
- Feed rate: Depending on the laser power I choose f = 100 - 300 mm / s.
- PCB etching: To remove the exposed photo sensitive layer I used sodium hydroxide (1 g / 100 ml water). In about 30 - 90 sec. all was gone. To remove the copper layer I used HCl/H2O2. Be careful with this mixture, it is very corrosive (I am a chemist by training and know what I do ..). I also tried sodium persulfate (Na2S2O8, 200 g / l , 40 - 50 °C) which is almost harmless and works fine also.
