Arduino Metrophones
More Aware with Less Distraction when Crucial
The metropolitan in it's natural habitat; unaware, oblivious, purposefully deafened and subsequent prey. To increase perception thus safety, we wed an Arduino Nano and ultrasonic sensor to regulate volume to proximity to some one behind you; easily deactivated per environment and rechargeable. Beyond this proof of concept, intention for apparel or accessory (purse, back pack) embedding is ideal.
(Disclaimer) TVMiller is NOT a metro-any-dang-thing!
This prototype of a prototype is a mono-version. A stereo version would merely require dual channels (pots). Aptly, imagine if you will, you plug your head phones in to your purse strap which is embedded with a Metrophone with bluetooth that streams to your smart phone...or or or you could PAY ATTENTION! Sorry not sorry.
Add the HackADay Skull and Wrenches logo to your project...
https://hackaday.io/project/11709-hackaday-sketchup-logo
  • 1 × Arduino Nano Arduino IDE
  • 1 × Digital Potentiometer 10K
  • 3 × CR2032 Rechargeable Coin Cell
  • 1 × Stereo Jack
  • 1 × USB Female
View all 9 components
  • Arduino Sketchy Sketcherson
    Vije Miller05/13/2016 at 16:13 0 comments
    // MetroPhones
    // TVMiller
    #include <SPI.h>
    // Chip Select Pin
    int csp = 10;
    // Sensor Values
    long dur, dis;
    // Echo Pin
    int echo = 4;
    // Trigger Pin
    int trig = 5;
    // Position
    int pos = 0;
    // Centimeters
    // Minimum Distance
    int mindis = 0;
    // Maximum Distance
    int maxdis = 90; // 2.6FT
    void setup() {
      // Pot Com
      SPI.begin();
      pinMode(csp, OUTPUT);
      // Set Chip Select LOW
      digitalWrite(csp, LOW);
      // Testing
      Serial.begin (9600);
      // Sensor Pins
      pinMode(trig, OUTPUT);
      pinMode(echo, INPUT);
    void loop() {
      // Poll Sensor
      digitalWrite(trig, HIGH);
      delay(10);
      digitalWrite(trig, LOW);
      dur = pulseIn(echo, HIGH);
      // Convert to Centimeters
      dis = dur / 58.2;
      if (dis < maxdis) {
        // Convert Distance to Pot (256 Steps)
        pos = map(dis, mindis, maxdis, 0, 255);
        // Alert Chip
        SPI.transfer(0);
        // Adjust Volume
        SPI.transfer(pos);
      } else if (dis > maxdis) {
        pos = 255;
        SPI.transfer(0);
        SPI.transfer(pos);
      // Testing
      Serial.print(dis);
      Serial.print("  ");
      Serial.println(pos);
      delay(100);
  • Fritz Fritzerson
    Vije Miller05/13/2016 at 16:10 0 comments
    Mono-prototype-version.
    Stereo-version simply requires another MCP3141 digital pot.
View all 2 project logs
pixelbomb wrote 09/02/2018 at 18:44 point
This project has a skull on it which makes me think that you support pirating. Do you know how much money famous people lose each year because of open sea pirating.
