Hackaday.bash.org
TODO: recreate using 555
Let the Snipping Tool be with you. Alternatively, use that "Prt Sc" button.
Join this project if you have something to share. Whatever, join even if you don't.
Check out #documentation screenshots by @jaromir.sukuba!
Also, #Benchoffisms!
View all 89 project logs
tyler wrote 08/31/2021 at 02:34 point
follower number 69!
Arya wrote 08/31/2021 at 04:13 point
nice
davedarko wrote 08/31/2021 at 08:06 point
nice
numinit wrote 12/24/2016 at 06:26 point
Yann Guidon / YGDES wrote 12/24/2016 at 06:37 point
nice one... but how do you run it ?
numinit wrote 12/24/2016 at 06:45 point
Grab the Tampermonkey (Chrome) or Greasemonkey (Firefox) userscript manager and click "Raw" - it will open a prompt to install, since the extension is .user.js
Edit: After 30 seconds of editing, it now removes the "Recent comments" sidebar, too. Knock yourself out.
Edit 2: Now it completely gets rid of all hints that comments might exist on hackaday, in addition to the comments themselves.
Ted Yapo wrote 12/24/2016 at 15:06 point
Works like a charm. Best. Hack. Ever.
Arya wrote 12/27/2016 at 03:33 point
But... But that's not the point. Once you learn to filter the comments in your mind, you can sometimes learn from the comments as much or more than you could learn from the article itself.
Other than that, great hack and I see how that could be useful!
numinit wrote 12/27/2016 at 03:35 point
Great thing about Tampermonkey is that you can toggle userscripts on and off, as I do sometimes on hackaday :)
Arya wrote 12/27/2016 at 04:56 point
Good point, and i just got a reminder of why people might want to disable comments.
Yann Guidon / YGDES wrote 09/21/2016 at 02:39 point
Shouldn't this project be called bash.hackaday.io ? :-P
[deleted]
Arya wrote 10/13/2016 at 19:47 point
For replacing "skulls" with "likes", for one
K.C. Lee wrote 08/07/2016 at 19:41 point
If a picture is worth a thousand words, then this SPAM lady loves the strong silent mystery type.
Eric Hertz wrote 06/05/2016 at 21:59 point
Does this count?
I wonder what 0.01 bytes would look like!
Arya wrote 06/06/2016 at 01:38 point
Somehow never noticed this before! Definitely does.
Nathan A. Fain wrote 07/18/2016 at 11:59 point
0.01 is necessary to maintain one bit's charge in RAM.
K.C. Lee wrote 07/18/2016 at 14:56 point
Must be an Arduino thing using floats for everything that normally an int would do.   :P
Greg Kennedy wrote 11/04/2016 at 19:47 point
Yay, JavaScript.
