Tit
A supercharged Arduino pro-mini compatible board with Atmega328pb
Ever wanted to have two hardware Serial Ports, two SPI, two I2C and more PWM pins on the Arduino Pro Mini? Tit has all of this, and retains the same form factor. Tit uses Atmega328PB at its core.
Tit, is pin compatible with Arduino Pro Mini, the chip Atmega328pb is software compatible with Atmega328p. Hence all the existing code and libraries should work without any changes. Tit uses higher version of avr-gcc toolchain, we have bundled it up as a package along with additional libraries required to access the extra features.
Check this detailed tutorial on setting up Tit for different operating systems.
http://exploreembedded.com/wiki/Tit,_a_supercharged_Arduino_Pro_Mini_with_Atmega328pb
Tit is up for sale:
India: https://www.
Tit, the name:
The board is named after the bird Tit.
https://en.wikipedia.org/wiki/Tit_(bird)
Features:
  • Processor: Atmega328pb
  • Speed: 16MHz
  • Flash: 32KB
  • RAM : 2KB
  • EEPROM: 1KB
  • GPIOs x24
  • Analog Channels x 8
  • HW UARTs x 2,
  • SPI x 2
  • I2C x 2
  • PWM x 9
  • Interrupt Pins x 2
  • Unique HW ID
  • Castellated Pads
  • Pin compatible with Arduino Pro-Mini
Project Status
  • Tool chain tested on windows and linux 64 bit systems. Please check the project in reference section for more details on this.
  • PCB designed in KiCAD and firmware is up and running
  • Bootloader, both UARTs, i2c, additional PWMs and all GPIOs have been tested.
To Do:
  1. Test the tool chain on MAC and linux 32 bit
  2. Test additional SPI and I2C interfaces
  3. Library for accessing unique hardware id of the device.
References and Credits:
Thanks to work by Andre Moehl on *uino Mini Super (Atmega328PB) project on hackaday.io https://hackaday.io/project/9313-uino-mini-super-atmega328pb
View all 4 project logs
Jarrett wrote 05/19/2016 at 21:32 point
Can I find tits on the internet yet?
Sandeep Patil wrote 05/20/2016 at 13:44 point
Not yet, we are in the process of making the first batch.
Sandeep Patil wrote 05/17/2016 at 03:53 point
@Hans Olo Thanks, the price will be between $6 to $9. Not decided it, we have got the PCBs and passives waiting for the chip.
Winston wrote 05/05/2016 at 14:52 point
Very nice, but where can I actually buy one?
Sandeep Patil wrote 05/05/2016 at 15:15 point
Thanks! A small batch is in the making, will update the link to buy in a few days.
Hans Olo wrote 05/16/2016 at 18:45 point
Hurry up. I'd love to order a pair of tits :D
Any idea about the price yet?
