For some more details, please visit the GitHub page of this project.
Explanation of Front Panel
Some YouTube Videos
Description of the Microtronic, its CPU and Machine Language
I was asked to provide some more details about the Microtronic and its machine language. Here we go:
The Microtronic is a very simple computer. It is programmed in a custom machine language, called 2090 ML in the following. 2090 ML is a virtual machine language, interpreted by the monitor program / operating system of the Microtronic. The original Microtronic uses a TI TMS 1600 Microcontroller, clocked at 500 kHz, and executes 2090 ML at a speed of a couple of 2090 ML instructions per second. This Microtronic Emulator runs on an Arduino Mega 2560, and the interpreter and operating system / monitor program was "reengineered" in C (I don't have the original TMS 1600 machine code of the operating system / monitor program). The emulator achieves a higher speed than the original Microtronic, but it can be throttled down with a pot.
The Microtronic program memory has 256 words of 12 bits. It has two sets of 16 universal 4 bit wide registers, 0 - F. There are instructions to swap / exchange the work and aux register sets. The CPU has Carry and Zero flags, and offers conditional and unconditional branching, as well as subroutines. The original Microtronic disallowed subroutine calls from subroutines due to the lack of a stack for storing the program counter, but my emulator allows nested subroutine calls (and the stack size is adjustable).
The 2090 ML was designed under didactic and pedagogic considerations, offering high-level instructions for otherwise tedious (or impossible) to implement operations, e.g., decimal multiplication and division, hexadecimal to decimal conversion (and vice versa), real time clock, random generator, display output, etc. The program memory is read only; the only write able memory is register memory. In a sense, the Microtronic implements a Harvard Architecture, with the only (write able) data memory being the register memory.
With regard to IO, there are instructions for displaying register content on the 6digit 7segment display. There is 4 bit wide digital input, and a 4 bit wide output port. Also, there is an instruction that waits for input from the hexadecimal keypad and stores it into a register.
A Simple Microtronic Example Program
To give a first example for 2090 ML, a simple digital 4bit counter on the LED 7segment as well as the 4 digital output LEDs looks as follows:
Address Mnemonics OP   Comment
00      MOVI 00   100   Load 0 into register 0
01      DISP 10   F10   Display 1 register, starting at 0
02      ADDI 10   510   Add 1 to register 0
03      DOT  0    FE0   Bring register 0 to output port
04      GOTO 02   C01   Goto address 01
The Microtronic Instruction Set
In the following, the 2090 ML instruction set is listed. I use the following notation: s = source register (0-F), d = destination register (0-F), n = 4 bit immediate constant (0 - F), and aa = 8 bit address (00 - FF). reg(d) denotes the content of register d (0 - F). The aux registers are denoted by 0' - F'. Unless indicated otherwise, flags don't change. "... -> d" means copy ... into register d. I am using standard C operators, i.e. "&" is bitwise AND, "|" is bitwise OR, then there are left and right shift operations ">>" and "<<" An "I" suffix to the Mnemonics means "immediate", and "iff" means "if and only if".
Two address instructions:
MOV   = 0sd : reg(s) -> d.
        Zero if reg(d) = 0.
MOVI  = 1nd : n -> d.
        Zero if reg(d) = 0.
AND   = 2sd : reg(s) & reg(d) -> d
        Carry = false. Zero iff reg(d) = 0.
ANDI  = 3nd : n & reg(d) -> d.
ADD   = 4sd : reg(s) + reg(d) -> d.
        Carry iff overflow. Zero iff reg(d) = 0.
ADDI  = 5nd  n + reg(d) -> d.
SUB   = 6sd : reg(d) - reg(s) -> d.
        Carry iff underflow. Zero iff reg(d) = 0.
SUBI  = 7nd : reg(d) - n -> d.
CMP   = 8sd : compare reg(s) and reg(d).
        Carry iff reg(s) < reg(d). Zero iff reg(s) = reg(d).
CMPI  = 9nd : compare reg(d) with constant n.
        Carry iff n < reg(d). Zero iff n = reg(d).
OR    = Asd : reg(s) | reg(d) -> d
Branching instructions:
CALL  = Baa : goto subroutine at address aa.
              Use RET to return.
GOTO  = Caa : goto address aa.
BRC   = Daa : branch iff carry to address aa.
BRZ   = Daa : branch iff zero to address aa.
One address instructions:
MAS  = F7d : move work register d into aux register d:
             reg(d) -> d'.
INV  = F8d : invert reg(d) (one's complement).
SHR  = F9d : shift right: reg(d) << 1 & 15 -> d.
             Carry iff reg(d) & 8 (before execution).
SHL  = FAd : shift right: reg(d) >> 1 & 15 -> d.
             Carry iff reg(d) & 1 (before execution).
ADC  = FBd : add carry. reg(d) + carry -> d.
SUBC = FCd : subtract carry. reg(d) - carry -> d.
Input / output instructions:
DIN = FDd : data in. Read current digital inputs
            and store into register d.
DOT = FEs : data out. Set digital output to reg(d).
KIN = FFd : keyboard in. Halt program and wait for
            hex keypad input. Store into register d.
Display instruction:
DISP = Fns : display reg( ( s+n-1 ) % 16) ... reg(s)
             on the display.
Special instructions:
HALT  = F00 : stop program.
NOP   = F01 : no operation.
HXDZ  = F03 : convert hexadecimal number with digits
                   reg(F) reg(E) reg(D) to decimal.
              After conversion,
                   reg(F) reg(E) reg(D) is decimal.
              Carry = false.
              Zero iff overflow, i.e., hex number > 3E7.
DZHX  = F04 : convert decimal number with digits
                   reg(F) reg(E) reg(D) to hexadecimal.
              After conversion,
                  reg(F) reg(E) reg(D) is hexadecimal.
              Carry = false. Zero = false.
RND   = FO5 : random generator.
              Assign random numbers to registers F, E, D.
TIME  = FO6 : get real time.
              Assign current real time clock time to
              registers A - F. Time format HH : MM : SS =
              reg(F) reg(E) : reg(D) reg(C): reg(B) reg(A).
RET   = F07 : return. Return from subroutine.
CLEAR = F08 : clear work registers.
              Carry = false. Zero = true.
STC   = F09 : set carry flag.
              Carry = true.
STC = F0A   : reset carry flag.
              Carry = false.
MULT = F0B  : multiplication. Multiply the decimal number
              with digits
               reg(5) reg(4) reg(3) reg(2) reg(1) reg(0)
              with aux registers
          reg(5') reg(4') reg(3') reg(2') reg(1') reg(0')
              and store result in registers 5 to 0.
              Carry = true iff overflow (result > 999999).
              Zero = false.
DIV  = F0C  : division. Divide the decimal number
              with digits
              through aux registers
              and store result in register 3 to 0. The
              division rest is stored in registers 3' to 0'.
              Carry = true iff error.
              Zero = false.
FOD  = EXRL : exchange least significant registers.
              Swap work with aux registers
                     0 - 7 <-> 0' - 7'.
FOE  = EXRM : exchange most significant registers.
                     8 - F <-> 8' - F'.
FOF  = EXRA : exchange all registers.
                     0 - F <-> 0' - F'.
The Monitor Program / Operating System
How do you program a Microtronic (Emulator)? It is simple. Turn it on. Then, specify the start address of your program: HALT-NEXT-00. Next, enter the program, and use NEXT after each instruction. This advances to the next memory location.
100 NEXT
F10 NEXT
510 NEXT
FE0 NEXT
C01 NEXT
To start this program at address 00, press HALT-NEXT-00-RUN. You should now see a one-digit hex counter on the 7segment LED display, and the 4 DOT output LEDs shows the displayed number in binary. Use the CPU throttle to slow down the CPU such that you can read the numbers better.
To stop the running program, press HALT. To step through the program in memory, use HALT-NEXT-00 -NEXT-NEXT-NEXT-... etc. Use the ENTER button to toggle LCD display to show Mnemonics of the op codes displayed on the 7segment LED display.
During execution, use the ENTER button (green button under the LCD display) to toggle through CPU status pages. One page shows current PC and breakpoint address, as well as address, op code, and mnemonic and CPU speed. Moreover, you can show the contents of the 16 work and aux registers on the next page.
Unless the emulator is in load / save mode (in that case the buttons under the LCD display are used for SDCard directory browsing and file creation), you can use the buttons to trigger the Emic 2 speech synthesizer:
The left digit of the 7segment display shows the following status codes:
Description of the Function Buttons
Description of the Built-In PGM (EEPROM) Programs
The .MIC File Format and Example Programs
The software directory on the GitHub page (as well as the files section of this page) contains some programs from the Microtronic manuals and the book "Computer Games (2094)". You can put these files on a FAT16 formatted SDCard, and load them via PGM 1. Please refer to the original manuals on how to use these programs. It is a simple ASCII format. I have created most of those files using an OCR programm, by scanning the original manuals.
In a .MIC file, you will find one 12 bit word / op code per line (e.g. 510). Comments start with a # and go until the end of that line. The is also the origin directive, @ xx. This means that the next instruction(s) will be stored from programm adress @ xx on. Most of the time, you will find @ 00 at the beginning of a .MIC file. If a .MIC does not contain a @ xx, then the program will be loaded at the current PC. That way, programs can be relocatable (e.g., for subroutines), and loaded at different addresses. A file can contain more than one @ xx.
