First one assembled
A project log for AutoResetRRR
A project out of frustration. Automatic reset for misbehaving hardware.
electrobobelectrobob • 05/23/2016 at 19:33•0 Comments
The first device skips the 5V regulator, as I am testing it with a raspberry pi. Everything is red, even the LED. I began to test it for the raspberrry pi as this needs the additional python software required to shut-down the pi safely. I am thinking to implement the functionality of a power button as well, will be a simple one, since the Pi does not have such functionality.
DSC_5624To contact the side ISP connector I use a home made PCB with a simple 90 degrees connector with pins slightly bent
DSC_5627
And brief tests with the Pi, shutdown during the warning time works smoothly.
DSC_5632
