Initial testing
05/03/2016 at 21:38 • 0 commentsI performed 3 tests today
- Soldering 0805 and 0402 components to a throwaway PCB board
- Soldering a 28 pin TSSOP to a breakout
- Desoldering components from an existing board
For the soldering tests, I did not have a stencil available so I just sloppily place paste directly from the tube. Even so, the solder wicked its way to the pads and I was able to solder very small parts without tombstoning. The soldering time was about 90 seconds to reflow.
For the desoldering test, I used a non function MSP430 launchpad. As the board exceeded the size of the heater, I put pressure on the board against the heater. It took about 2-3 minutes until I was able to remove the TUSB and the large MSP430 chip.
The tests show that the self regulating behaviour of the PTC heater works very well for hot plate soldering. I did not require a controller or arduino of any kind to get results!
Analog Two
