WiFi Webradio on ESP8266 or ESP32
KaRadio A fully featured wifi web radio player with only low cost boards. with or without a vs1053 board
Control with any browsers (ie edge, chrome mozilla etc...). or with an external hardware panel or with the uart interface or with telnet. Memory for 255 stations OTA (On the Air) upgrade, Read direct mp3 or ogg or WMA streams or playlist .pls .m3u, asx and .xspf Read up to a 320 kb/s stream, Encoder, IR, lcd ... Embedded wifi configuration via the web or serial or telnet. Metadata displayed (ie Title of the current song if given in the stream), Permanent setting (sound setting, stations, wifi) Server multi clients with automatic refresh (websocket), The stations may be downloaded and uploaded within the web site, Stations sort management by drag drop. very quick responsive web by caching local information in the browser and websocket. additional hardware: a led indicates the state of the equipment Optional: control switches, lcd display, additional ram for buffering
See http://www.instructables.com/id/Wifi-Webradio-With-ESP8266-and-VS1053 for the description of the minimal prototype.
See Github for sources
See github source for the ESP32 version ( vs1053 or i2s or pcm or internal DAC)
See A project derived from KaRadio32 in progress.
See the lcd +IR software's on Github AddOn
See some realizations of users at KaraDio
A nextion touchscreen display for KaraDio from yo2ldk : Here
For more informations or questions, you can enter to the Karadio facebook group
Release 2.4 Rev 1 -
 Built on 2026/03/08
  • 2.3 Rev 0 - Built on 2022/02/23
  • Real time optimizations
  • 2.3 R0:
    • RAM optimization
    • Audio buffer size incremented.
    • Bugs correction: HTML chunks processing and Meta computing
    • Stack crash on http instant command removed
    • AAC Decoding improved
  • 2.2 R1:
    • Introducing WIFI QoS Ip precedence AC_VI
    • SPDIF output improved
    • DAC bugs removed.
    • AAC Decoding improved (but not perfect)
    • New patch for the vs1053. Play OGG too.
  • 2.2 R0:
    • Many internal optimizations
    • ascii unicode #&xxxx; decoded
    • aac decoder improved.
    • Added html commands volume+ and volume-
    KaRadio: Release 2.1
    Release 2.1 R0 - Built on 2021/02/15
    • 2.1 R0:
      • Security: the ssid passwords are no longer sent on each "Setting" display, but only when changed.
      • Bug fixed: in parse playlist. Possible memory leak. Thanks to HmarikBel
      • Bug fixed: Special char in station name was incorrectly sent.
      • Some minors improvements.
    • 2.0 R0:
      • Better handling of the large "header moved"
      • Better monitoring
      • timezone suggestion on the setting page
    History:
    history
    For ESP32 see the github page KaRadio32.
    ESP8266 Simplest prototype:
    - Optional external ram (23LCV1024) support (1:CS/=GPIO16 2:MISO=GPIO12 3:NC 4:GND 5:MOSI=GPIO13 6:SCK=GPIO14 7:GND 8:3.3v)
    Attention:
    The optional led is now on GPIO2. The blue led on the ESP8266 is blinking at the same rate.
    GPIO16 is now the Chip select for the external ram if any.
    The external ram is detected at boot time if present.
    To upgrade to this release, please flash user1.4096.new.4.bin at 0x1000 ,
    user2.4096.new.4.bin at 0X81000 and blank.bin at 0x7e000 & 0x3fe000
    After that, all next updates are done with the On The Air (OTA) feature.
    New binaries are hosted at http://karadio.karawin.fr .
    Loading the esp8266
    First use
    • If the access point of your router is not known, the webradio initializes itself as an AP. Connect your wifi to the ssid "WifiWebRadio",
    • Browse to 192.164.4.1 to display the page, got to "setting" "Wifi" and configure your ssid ap, the password if any, the wanted IP or use dhcp if you know how to retrieve the dhcp given ip (terminal or scan of the network).
    • In the gateway field, enter the ip address of your router.
    • Validate. The equipment restart to the new configuration. Connect your wifi to your AP and browse to the ip given in configuration.
    • Congratulation, you can edit your own station list. Don't forget to save your stations list in case of problem or for new equipments.
    • if the AP is already know by the esp8266, the default ip at the first start is 192.168.1.254
    • a sample of stations list is on https://github.com/karawin/Ka-Radio/blob/master/ESP8266-Firmware/WebStations.txt . Can be uploaded via the web page.
    Feedback
    Please tell me if you succeeded or something more can be done, thanks.
    The second step will add some hardware buttons (vol + -, station + -, play ...)
    Wiring:
    From ESP8266_ESP12( 3.3 v) or nodeMCU(5v) to VS1053 (5 v)
    REST
    ADC
    CH_PD to 3.3v
    GPIO16 (a 1Hz output)
    D5:GPIO14 to VS1053 SCK...
KaRadio32.bin
V2.4R1
octet-stream - 1.49 MB - 03/09/2026 at 19:21
Download
KaRadio 2.1 R1 Partition 1
application/octet-stream - 424.75 kB - 01/11/2020 at 18:13
Download
KaRadio 2.1 R1 Partition 2
Download
boot_v1.7.bin
octet-stream - 3.98 kB - 09/17/2017 at 10:26
Download
blank.bin
octet-stream - 4.00 kB - 07/21/2016 at 15:19
Download
View all 6 files
  • 1 × ESP8266 http://www.ebay.fr/itm/121775761053?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
  • 1 × VS1053 http://www.ebay.fr/itm/401046111343?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
  • 1 × USB to TTL http://fr.aliexpress.com/item/USB-to-TTL-converter-UART-module-CH340G-CH340-3-3V-5V-switch/32392228218.html?detailNewVersion=2
  • 1 × MB102 Power supply http://fr.aliexpress.com/item/MB102-Breadboard-Power-Supply-Module-3-3V-5V-For-Solderless-Breadboard/2027279953.html
  • 1 × or nodeMCU clone http://fr.aliexpress.com/item/NodeMcu-Lua-WIFI-development-board-based-on-the-ESP8266-Internet-of-things/32338129505.html
View all 6 components
View all 11 project logs
  • 1
    Step 1
    Wiring:
    REST:
    ADC : gound if control panel not used
    CH_PD to 3.3v
    GPIO16 led output
    D6:GPIO12 to VS1053 MISO (or so)
    D7:GPIO13 to VS1053 MOSI (or si)
    TXD to CH340G UART rx
    RXD from CH340G UART tx
    D1:GPIO05 to VS1053 XDCS
    D2:GPIO04 to VS1053 DREQ
    D3:GPIO00 to VS1053 XRST
    GPIO02
    D8:GPIO15 to VS1053 XCS
View all instructions
Isabella Beck wrote 01/30/2024 at 06:49 point
Kudos to you! https://launcestonfencing.au/
Colton Owens wrote 01/30/2024 at 06:48 point
Important topic. https://joondalupfencing.au/
Diverse perspectives, nice! https://goldcoastpoolfencing.au/
Sophia Thornton wrote 01/30/2024 at 06:44 point
Love your style. https://glasspoolfencingperth.au/
Made me think. https://glasspoolfencingmelbourne.net.au/
Caleb Hawkins wrote 01/30/2024 at 06:42 point
Clear and concise. https://gladstonefencing.com/
Relatable content. https://geraldtonfencing.au/
Jasmine Ng wrote 01/30/2024 at 06:40 point
Thanks for sharing. https://fencingbunbury.au/
Good job! https://centralcoastfencing.au/
Cameron West wrote 01/30/2024 at 06:38 point
Eye-opening! https://canberrafencingcontractors.au/
Great insights. https://campbelltownfencing.au/
Maddison Klein wrote 01/30/2024 at 06:36 point
Well done! https://brisbaneglasspoolfencing.com.au/
Interesting read! https://boombafencing.au/
Eliana McCarthy wrote 01/30/2024 at 06:34 point
Totally agree! https://bendifencing.au/
Eliana McCarthy wrote 01/30/2024 at 06:29 point
Nice post! https://adelaidefencingservices.au/
stefanvasiliu wrote 05/24/2023 at 10:23 point
Hello, i`m on ESP8266, how i can add addon for
LCD? I see some addon for LCD. Example: https://github.com/karawin/karadio-addons/commit/1bd42de873ee3bf50dd6c47c6af4293200a40f20
stchse wrote 04/02/2022 at 20:30 point
Can somebody please help me. When running KaRadio32 on a ESP32-Wroom-V4 together with a VS1053/1003, but also when using a UDA1334A via I2S, I get an audio signal on just one channel.
jimsonweed wrote 02/13/2022 at 16:58 point
Hello! There is a glitch while used hardware decoder vs1053b on this station http://hirschmilch.de:7000/listen.pls?sid=3
NoOne38 wrote 02/13/2022 at 16:55 point
Bonjour Je me permets de vous déranger , je viens de réaliser la dernière version 2.2 R1 un grand merci tout d'abord pour votre super boulot, j'essaie de mettre un ST7735 I2C comme écran et après plusieurs tentatives je n'y suis pas arrivé ( par contre LCD_SPI_ILI9341  et   LCD_I2C_SSD1306 fonctionnent parfaitement)
Auriez-vous des conseils de câblage svp ?  (  CS,DC,RST,SDA et SCL)
merci encore
Jean-Pierre Cocatrix wrote 02/13/2022 at 17:17 point
et en lisant https://github.com/karawin/Ka-Radio32 ?
C'est souvent les pin qui changent de nom. Il faudra aussi configurer le bon type de lcd par serial ou telnet. ou dans un fichier csv.
NoOne38 wrote 02/13/2022 at 17:46 point
c'est un ST7735 128x128 mais I2C pas un SPI et je n'ai pas trouvé de code équivalent j'ai pourtant  essayé le câbler en I2C sur  :
// I2C lcd (and rda5807 if lcd is i2c or LCD_NONE) //------------------------------------------------
#define PIN_I2C_SCL GPIO_NUM_14
#define PIN_I2C_SDA GPIO_NUM_13
#define PIN_I2C_RST GPIO_NUM_2 // or not used
peut-être avec un autre code serial mais lequel je n'ai pas vu d'équivalence dans la liste
frank.mertin wrote 12/02/2021 at 15:24 point
Hello!
First of all this is a great project. Is it possible, to add a rotary encoder or some buttons for changing the saved favourite radio stations? This would be a great feature, especially for people who don't want use a smartphone.
Thanks in advance
Frank
