WiFi Webradio on ESP8266 or ESP32
KaRadio
A fully featured wifi web radio player with only low cost boards.
with or without a vs1053 board
Control with any browsers (ie edge, chrome mozilla etc...).
or with an external hardware panel or with the uart interface or with telnet.
Memory for 255 stations
OTA (On the Air) upgrade,
Read direct mp3 or ogg or WMA streams or playlist .pls .m3u, asx and .xspf
Read up to a 320 kb/s stream,
Encoder, IR, lcd ...
Embedded wifi configuration via the web or serial or telnet.
Metadata displayed (ie Title of the current song if given in the stream),
Permanent setting (sound setting, stations, wifi)
Server multi clients with automatic refresh (websocket),
The stations may be downloaded and uploaded within the web site,
Stations sort management by drag drop.
very quick responsive web by caching local information in the browser and websocket.
additional hardware: a led indicates the state of the equipment
Optional: control switches, lcd display, additional ram for buffering
See http://www.instructables.com/id/Wifi-Webradio-With-ESP8266-and-VS1053 for the description of the minimal prototype.
See Github for sources
See github source for the ESP32 version ( vs1053 or i2s or pcm or internal DAC)
See A project derived from KaRadio32 in progress.
See the lcd +IR software's on Github AddOn
See some realizations of users at KaraDio
A nextion touchscreen display for KaraDio from yo2ldk : Here
For more informations or questions, you can enter to the Karadio facebook group
KaRadio32 Release 1.9
KaRadio32:
Release 1.9 Rev4 - Built on 2019/04/28
New:
  • 1.9 R4:
    • wifi.auto command now disable the AP mode if already connected to an AP in the past.
    • I2S corrected for 32bit output stream. Thanks to har-in-air github user.
    • Instant play: new button "Add/Edit", and update fields on cli commands.
  • 1.9 R3:
    • blank password accepted.
    • New lcd types: LCD_I2C_ST7567, LCD_SPI_ST7567_pi , LCD_SPI_ST7567, LCD_SPI_ST7565_NHD_C12864
    • New nvs_partition_generator.sh and nvs_partition_gen.py: comment line # comment, now permitted.
    • cli.list correction.
    • Minor corrections.
  • 1.9 R2:
    • New option for the active level of buttons.
    • Little bug removed on color lcd.
    • Telnet disabled in AP mode.
    • Key Ctrl space, Ctrl left, ctrl right, ctrl top, ctrl bottom on web page for control.
  • 1.9 R1:
    • Labels in the csv hardware configuration.
    • Toggle main/time now permanent. On time display, an event go to the main screen for 3 seconds then return to time screen.
    • More reactive display on lcd.
  • 1.9 R0:
    • Improved encoder for new chinese device (shorter pulses) (reverse A/B in case of reverse way)
    • Better vs1053 detection.
    • No more fall back to i2s when the vs1053 is not detected.
    • RSSI display needed a click of a button to start.
    • AP mode on init: the web page starts on the "Setting" panel and the stations list is skipped.
    • Wifi option: If wifi is disconnected choose to reset or wait for the connection on the same SSID:
    • Command wifi.auto("x") with x = 0: reboot, x=1: wait for the SSID
    • For internal reasons, the touch screen needs to be calibrated again.
    • Many small improvements in the code.
KaRadio: Release 1.9
Release 1.9 R4 - Built on 2019/05/26
New:
  • 1.9 R4:
    • LWIP layer tuned. Better errno 11 computing.
  • 1.9 R3:
  • 1.9 R2:
    • AP mode no working. A wrong lwip was the cause. Now 192.168.4.1 is working.
  • 1.9 R1:
    • Keyboard on web page correction.
  • 1.9 R0:
    • Use of the RTOS SDK 2.0.0.
History:
history
For ESP32 see the github page KaRadio32. Release 1.6 R4
ESP8266 Simplest prototype:
... Read more »
user1.4096.new.4.bin
KaRadio 1.9 Rev4 AP corrected
octet-stream - 421.50 kB - 08/02/2019 at 21:04
Download
user2.4096.new.4.bin
Download
KaRadio32.bin
KaRadio32 1.9 Rev 4
octet-stream - 1.40 MB - 06/05/2019 at 13:27
Download
octet-stream - 3.98 kB - 09/17/2017 at 10:26
Download
octet-stream - 4.00 kB - 07/21/2016 at 15:19
Download
View all 6 files
View all 6 components
View all 11 project logs
  • 1
    Step 1
    Wiring:
    From ESP8266_ESP12( 3.3 v) or nodeMCU(5v) to VS1053 (5 v)
    REST:
    ADC : gound if control panel not used
    CH_PD to 3.3v
    GPIO16 led output
    D5:GPIO14 to VS1053 SCK
    D6:GPIO12 to VS1053 MISO (or so)
    D7:GPIO13 to VS1053 MOSI (or si)
    TXD to CH340G UART rx
    RXD from CH340G UART tx
    D1:GPIO05 to VS1053 XDCS
    D2:GPIO04 to VS1053 DREQ
    D3:GPIO00 to VS1053 XRST
    GPIO02
    D8:GPIO15 to VS1053 XCS
View all instructions
vis22 wrote 01/25/2017 at 16:30 point
Many thanks.
vis22 wrote 01/24/2017 at 21:00 point
Many thanks!!!
I will try to connect the IR remote from the boom box.
P.S. Dear jp kokatriks, in the current version karadioU8glib.ino on github.com no strings the #define IR and the #ifdef IRLib2 ?
vis22 wrote 01/24/2017 at 18:05 point
Спасибо за совет.
Выход модуля питания 5V установлен конденсатор 220 мкФ.
Технический паспорт для vc1053 рекомендует конденсаторы 22 мкФ в силовых цепях.
Установленная на плате модуля С17 и С18 были сомнительными номинальным.
Под руки были только 100 мкФ.
В результате, цель достигнута, отказы прекратились.
Могу ли я узнать ИК-датчик схема проводки и способ настройки командных кодов ИК?
Jean-Pierre Cocatrix wrote 01/24/2017 at 18:12 point
In u8glibConf.h of the software:
**** Instruction for the IR module *****************************************************************************************
The model used here is from:
https://www.aliexpress.com/item/Hot-Selling-1pcs-New-Infrared-IR-Wireless-Remote-Control-Module-Kits-For-Arduino-Wholesale/32334118062.html?spm=2114.13010608.0.0.XzmgYk
or equivalent. Cost less than 1$
- Based on NEC protocol; Built-in 1 x AG10 battery;
- Remote control range: above 8m;
- Wavelength: 940Nm;
- Frequency: crystal oscillator: 455KHz; IR carrier frequency: 38KHz
// IR library
Install the library from https://github.com/cyborg5/IRLib2
Uncomment the #define IR  and the #ifdef IRLib2 at the beginning of the karadioU8glib.ino file.
The IR receiver pins:
From left to right (pin at bottom, sensor in front of you)
Gnd VCC Signal
The signal must be connected to
For mini #define PIN_IRRECV  2  or 3
For micro #define PIN_IRRECV  2  or 3 or 7
In karadioU8glig.ino:
//  Uncomment the following line to see the code of your remote control and report to the case the value
//        Serial.print("Protocol:");Serial.print(results.decode_type);Serial.print("  value:");Serial.println(results.value,HEX);
If you want to use another remote, you can see the code of the keys and modify the switch case for the needed function.
See IRremote.h  to add the protocol you need for the remote.
The tx of the pro mini must be connected to the rx of the esp12 but
Warning; the esp rx pin is not 5V tolerant, so if your pro mini is a 5v version we need to adapt the level.
See
http://www.instructables.com/id/Pi-Cubed-How-to-connect-a-33V-Raspberry-Pi-to-a-5V/
The value of the resistors is not critical. Only the ration 1/3 2/3 must be respected 1k and 2k for example)
Enjoy.
Sergio wrote 01/23/2017 at 23:40 point
Hi JP,
Autoplay dosn't work correctly, every time I turn the player on, I have to press the play button, to start the radio playing
Jean-Pierre Cocatrix wrote 01/24/2017 at 02:22 point
update please.
Sergio wrote 01/24/2017 at 11:00 point
With the last update, i don't have sound with any stations
Jean-Pierre Cocatrix wrote 01/24/2017 at 12:22 point
Do another ota update, and enter the command on uart:
sys.patch("0")
And reboot again.
I wonder why your prototype doesn't like the vs1053 patch.
Are you alone in the world? May be some other problem on wire can explain it?
Sergio wrote 01/24/2017 at 14:28 point
Till i'm update the player  to the last update works ok, the only problem was that the autoplay doesn´t work ok. No wire problems, i´ll try with the uart command that you said.
Sergio wrote 01/25/2017 at 00:10 point
now works, on 2 players i have to entered the command on the uart
Thanks, may be a problem with the VS1053 patch
Jean-Pierre Cocatrix wrote 01/25/2017 at 09:16 point
The vs1053 patch is the official one. No problem with it. May be a spi error on transfert? The wires are longs between the esp and vs?
vis22 wrote 01/23/2017 at 17:45 point
May be. The power supply used DC-DC step-down module LM2596 powered by the voltage regulator +12 V boom-box.
ESP8266-12 randomly stopped communication with VS1053, assuming a fault ESP8266-12 replaced it ESP8266-7 effect it is not received, the modules behave as well. Only extra capacitors ensure their reliable operation.
Jean-Pierre Cocatrix wrote 01/23/2017 at 18:13 point
May be a high frequency filter with a few pf, and a 22µf on the 5 volts only?
vis22 wrote 01/22/2017 at 19:04 point
The recommended VS1053 module has to install additional capacitors 22 microfarads in parallel of C17 and C18 to the supply chains. Without them, the module sometimes freezes.
Jean-Pierre Cocatrix wrote 01/22/2017 at 19:25 point
Never seen on more than 10 prototypes.
May be a power supply problem on your prototype before these regulators?
Paul wrote 03/14/2017 at 04:10 point
Hi, what caps do you recommend, just ceramic SMC's?
Jean-Pierre Cocatrix wrote 03/14/2017 at 18:07 point
I never experimented a freeeze of the vs1053.
archetix wrote 01/20/2017 at 06:07 point
HI T4SPAM,
exactly
amp would be activated only during playback
(It prevents clatter at start-up)
the rest suppresses  filter
Please excuse my bad English
(CZech > EN Google translate)  :-)
Thomas wrote 01/20/2017 at 08:00 point
Great. Pin D4(GPIO2) is already in use for LED on Button Interface.
But we can use Pin Playing 12 on LCD MCU as well.
Regards
Thomas
archetix wrote 01/20/2017 at 09:16 point
Pin D4 (GPIO2) is already in use for LED on Button Interface ...
I would therefore suggest a new feature firmware for ESP8266
configuration GPIO2
LED out
or
amp control
thus enabling control amplifier without display
Jean-Pierre Cocatrix wrote 01/20/2017 at 10:27 point
Yes, I can also add a sys command to choose between the blinking default and the playing status on gpio2
archetix wrote 01/20/2017 at 12:47 point
HI jp cocatrix,
It would be great
Thank you in advance
Archetix
Jean-Pierre Cocatrix wrote 01/20/2017 at 16:38 point
No problem. in the next release
sys.led("x")  with x=0 default blink, x=1 led On when playing (state saved in eprom)
Ok?
archetix wrote 01/20/2017 at 17:58 point
OK
Thank you very much
archetix wrote 01/19/2017 at 13:52 point
Hello I want to commend this great project.
I have a suggestion for a configuration option GPIO2
such as switch power amplifier
could be a useful function (standby mode)
Thank you...
Thomas wrote 01/20/2017 at 04:59 point
Hi Archetix,
i also tried to use  a Pam based amplifier beacause it is very cheap.
But i has very frustrating klicking when loudness is low. i guess your cirquit can eleminate that, right?
Regards
Thomas
Jean-Pierre Cocatrix wrote 01/20/2017 at 16:33 point
Well done for the ground to avoid loop!
vis22 wrote 01/15/2017 at 20:10 point
Thank you for your project, it is allowed to breathe life into my boom-box.
Jean-Pierre Cocatrix wrote 01/15/2017 at 20:53 point
You are welcome.
Sergio wrote 01/15/2017 at 14:59 point
The new updates, load into WEb browser more quickly than old versions.
Jean-Pierre Cocatrix wrote 01/15/2017 at 15:42 point
Yes, a bug in the websocket corrected.
Richard wrote 01/12/2017 at 15:48 point
I am finding the Nokia 5110 display a little unreliable.
I've changed the CLI baud rate to 28800 and the display shows the correct station data some of the time, but as you move through the stations, the display will stop updating.
The CLI data is still being sent as I can monitor it.
Is it worth trying a slower baud?
Jean-Pierre Cocatrix wrote 01/12/2017 at 16:00 point
With karadioNokia5110 or karadioU8glib?
It is not normal, but yes try a slower baud.
If it stop to display any change after stopping, something is wrong in your soft or wiring.
Richard wrote 01/12/2017 at 17:10 point
This was with the older Nokia5110. I just tried the U8glib version, but it's failing to build as Arduino IDE 1.6.5 can't find the U8glib header files...
satbk_2 wrote 01/10/2017 at 16:53 point
Hi all. Please tell me how can I connect the LCD module to this radio? Which module can be connected? Thank you
Jean-Pierre Cocatrix wrote 01/12/2017 at 16:06 point
mangup wrote 01/10/2017 at 08:05 point
Thanks for update!
Thomas wrote 01/10/2017 at 05:15 point
Morning JP,
thanks a lot for your work in Karadio and your newest update.
Now my stop button is working again :-)
Have a nice day
Thomas
polgrv wrote 01/08/2017 at 17:50 point
jp cocatrix,
thank you for what you've shared with us!
One note: both here and on the GitHub README.md you report 192.164.4.1 as setup page on the staring AP mode. For me was 192.168.4.1, but I've not changed anything in your files. Is it possible the published IP is wrong?
If it could be useful, to upload your files on the ESP working on Linux, I downloaded from GitHub esptool.py, I added the dependency to get it working, I copied in the esptool folder all the .BIN files and I just executed this shell command after I connected my NodeMcu board to the USB port:
python2.7 esptool.py --port /dev/ttyUSB0 write_flash -ff 40m -fm qio -fs 32m 0x00000 boot_v1.5.bin 0x01000 user1.4096.new.4.bin 0x81000 user2.4096.new.4.bin 0x7E000 blank.bin 0x3FE000 blank.bin 0xFC000 esp_init_data_default.bin 0x3FC000 esp_init_data_default.bin
This is my first running implementation (to replace the mono speaker I've already a small amp board and I've just to putt all in a box):
karadio_by_paolo
Boards from aliexpress, connection cable from an internal mainboard->front panel USB cable and a strip of female headers.
Jean-Pierre Cocatrix wrote 01/20/2017 at 16:44 point
Hello,
I haven't see your message befor. Sorry.
Yes a mistale in the README. Corrected thanks.
Thanks for the shell. I add it in the next delivery.
Thomas wrote 01/08/2017 at 08:31 point
Since my first Radio is still not fully build up i did a second one for the father of my Girlfriend.
I buld it up in a small stereo speaker which is used available for approx. 12€ on A...zon.
You can recognize it on the blue light of life :)
et="_blank">
Jean-Pierre Cocatrix wrote 01/08/2017 at 17:15 point
Well done!
ldv82 wrote 01/06/2017 at 19:17 point
jp cocatrix
I have a suggestion to add a button in the interface to reset the default tone.
To reset the EQ settings.
Jean-Pierre Cocatrix wrote 01/06/2017 at 20:41 point
ok, Easy ;-)
balaji wrote 12/29/2016 at 08:42 point
Hello,
I liked your project very much.
I have one question will this method work with Adafruits VS1053 mp3 codec
https://www.adafruit.com/product/1381
Thanks in advance
Balaji
Thomas wrote 12/28/2016 at 08:04 point
Hello together,
has anyone a idea how to play a local playlist, running on a computer in the own network?
I tried 192.168.2.176\radio\Madonna\Madonna.m3u
Im using Windows 7 and the folder is enabled for anybody
Regards
Thomas
Jean-Pierre Cocatrix wrote 12/28/2016 at 09:16 point
M3U is a playlist. Edit it and don't forget to add 192.168.2.176\ before the real stream mp3 or ogg or other. Or simply call it with the direct mp3 name.
Thomas wrote 12/29/2016 at 07:13 point
Thanks for your hints but i did not catch it.
I have created a folder wit a mp3 in it   D:\1\1.mp3
Folder 1 is enabled as 1. So in my opinion the path should be:
192.168.2.176\1\1.mp3
If i enter this into a new station he doubles the last entered statoin from above.
Can you tell me what i have to enter exactly for my shown example?
Thanks
Thomas
ldv82 wrote 12/28/2016 at 11:58 point
"Stream What You Hear" program sends sound from your computer sound card to the stream, but does not work well with me. Still, you can use VLC player to make the flow of the local network. I liked the other way. Shoutcast-dsp-1-9-0-windows (Winamp plugin) and SHOUTcastGUI (a simple server). All that will be playing in Winamp, will be transferred to the stream network.
Thomas wrote 12/29/2016 at 07:16 point
Hi Idv82, i will try later.
First i will understand the other way
Regards
Thomas
Jean-Pierre Cocatrix wrote 01/04/2017 at 15:11 point
No change on adc. The empty value is 1V, (I measured 0.98 on my proto)
The stop is at 0.19 here and play at 0.36
But it is possible to increase the range to 220. Ok
if ((adc >400) && (adc < 580)) // volume +
            vol = VS1053_GetVolume();
            if (vol <244)
                vol+=10;
//                printf("vol %d   vol1 %d\n",vol,vol1);
                sprintf(Vol,"%d",vol);
                setVolumew(Vol);
        else if ((adc >730) && (adc < 830)) // volume -
            if (vol >10)
                vol-=10;
                setVolumew(Vol);
        if (!inside)
            if (adc < 200) // stop
                inside = true;
                clientDisconnect();
            else if ((adc >278) && (adc < 380)) //start
                inside = true;
                sprintf(Vol,"%d",currentStation);
                playStation    (Vol);
            else if ((adc >830) && (adc < 920)) // station+
                inside = true;
                wsStationNext();
            else if ((adc >590) && (adc < 710)) // station-
                inside = true;
                wsStationPrev();
Jean-Pierre Cocatrix wrote 12/29/2016 at 10:01 point
KaRadio is a http stream player. It doesn't know about the file system of another computer  nor embed nfs or CIFS or uPnP protocol above tcp/ip. To play a file from a pc you need to convert it to a stream. Vlc can do that or any html server like apache or https://sourceforge.net/projects/miniweb/ and many other. Karadio send a get to this server to receive the stream, that's all it can do.
Hope this help
Thomas wrote 01/04/2017 at 15:00 point
Ok, that was not clear to me but it is logical. Setting up a own server is on my todo list for near future, but not now.
Did you changed the ADC Value for STOP in 1.1.3 ?
Stop Button does not work anymore. I measured voltage on ADC Pin when Stop is pressed. It is 0,202V so ADC should be 197. Could the Value be set to 220 in next release?
Regards
Thomas
