WiFi Webradio on ESP8266 or ESP32
KaRadio
A fully featured wifi web radio player with only low cost boards.
with or without a vs1053 board
Control with any browsers (ie edge, chrome mozilla etc...).
or with an external hardware panel or with the uart interface or with telnet.
Memory for 255 stations
OTA (On the Air) upgrade,
Read direct mp3 or ogg or WMA streams or playlist .pls .m3u, asx and .xspf
Read up to a 320 kb/s stream,
Encoder, IR, lcd ...
Embedded wifi configuration via the web or serial or telnet.
Metadata displayed (ie Title of the current song if given in the stream),
Permanent setting (sound setting, stations, wifi)
Server multi clients with automatic refresh (websocket),
The stations may be downloaded and uploaded within the web site,
Stations sort management by drag drop.
very quick responsive web by caching local information in the browser and websocket.
additional hardware: a led indicates the state of the equipment
Optional: control switches, lcd display, additional ram for buffering
See http://www.instructables.com/id/Wifi-Webradio-With-ESP8266-and-VS1053 for the description of the minimal prototype.
See Github for sources
See github source for the ESP32 version ( vs1053 or i2s or pcm or internal DAC)
See A project derived from KaRadio32 in progress.
See the lcd +IR software's on Github AddOn
See some realizations of users at KaraDio
A nextion touchscreen display for KaraDio from yo2ldk : Here
For more informations or questions, you can enter to the Karadio facebook group
KaRadio32 Release 1.9
KaRadio32:
Release 1.9 Rev4 - Built on 2019/04/28
New:
  • 1.9 R4:
    • wifi.auto command now disable the AP mode if already connected to an AP in the past.
    • I2S corrected for 32bit output stream. Thanks to har-in-air github user.
    • Instant play: new button "Add/Edit", and update fields on cli commands.
  • 1.9 R3:
    • blank password accepted.
    • New lcd types: LCD_I2C_ST7567, LCD_SPI_ST7567_pi , LCD_SPI_ST7567, LCD_SPI_ST7565_NHD_C12864
    • New nvs_partition_generator.sh and nvs_partition_gen.py: comment line # comment, now permitted.
    • cli.list correction.
    • Minor corrections.
  • 1.9 R2:
    • New option for the active level of buttons.
    • Little bug removed on color lcd.
    • Telnet disabled in AP mode.
    • Key Ctrl space, Ctrl left, ctrl right, ctrl top, ctrl bottom on web page for control.
  • 1.9 R1:
    • Labels in the csv hardware configuration.
    • Toggle main/time now permanent. On time display, an event go to the main screen for 3 seconds then return to time screen.
    • More reactive display on lcd.
  • 1.9 R0:
    • Improved encoder for new chinese device (shorter pulses) (reverse A/B in case of reverse way)
    • Better vs1053 detection.
    • No more fall back to i2s when the vs1053 is not detected.
    • RSSI display needed a click of a button to start.
    • AP mode on init: the web page starts on the "Setting" panel and the stations list is skipped.
    • Wifi option: If wifi is disconnected choose to reset or wait for the connection on the same SSID:
    • Command wifi.auto("x") with x = 0: reboot, x=1: wait for the SSID
    • For internal reasons, the touch screen needs to be calibrated again.
    • Many small improvements in the code.
KaRadio: Release 1.9
Release 1.9 R4 - Built on 2019/05/26
New:
  • 1.9 R4:
    • LWIP layer tuned. Better errno 11 computing.
  • 1.9 R3:
  • 1.9 R2:
    • AP mode no working. A wrong lwip was the cause. Now 192.168.4.1 is working.
  • 1.9 R1:
    • Keyboard on web page correction.
  • 1.9 R0:
    • Use of the RTOS SDK 2.0.0.
History:
history
For ESP32 see the github page KaRadio32. Release 1.6 R4
ESP8266 Simplest prototype:
... Read more »
user2.4096.new.4.bin
KaRadio 1.9 Rev4
octet-stream - 400.38 kB - 05/26/2019 at 20:20
Download
user1.4096.new.4.bin
KaRadio 1.9 Rev4
Download
KaRadio32.bin
KaRadio32 1.9 Rev 4
octet-stream - 1.40 MB - 05/18/2019 at 21:46
Download
octet-stream - 3.98 kB - 09/17/2017 at 10:26
Download
octet-stream - 4.00 kB - 07/21/2016 at 15:19
Download
View all 6 files
View all 6 components
View all 11 project logs
  • 1
    Step 1
    Wiring:
    From ESP8266_ESP12( 3.3 v) or nodeMCU(5v) to VS1053 (5 v)
    REST:
    ADC : gound if control panel not used
    CH_PD to 3.3v
    GPIO16 led output
    D5:GPIO14 to VS1053 SCK
    D6:GPIO12 to VS1053 MISO (or so)
    D7:GPIO13 to VS1053 MOSI (or si)
    TXD to CH340G UART rx
    RXD from CH340G UART tx
    D1:GPIO05 to VS1053 XDCS
    D2:GPIO04 to VS1053 DREQ
    D3:GPIO00 to VS1053 XRST
    GPIO02
    D8:GPIO15 to VS1053 XCS
View all instructions
Eugene wrote 12/21/2017 at 14:18 point
Hello Jean-Pierre, thank you very much for your wonderfull project. I have some problem with lcd display ( ili9341) initialization . I can see just:
Karadio
(c) Karawin
IR+clcd V1.1
IP:
and nothing more. I use arduino pro mini + lcd ili 9341 + karadioUCglib. Uart speed 28800 same on arduino and esp 12f. (ucglibConf: Ucglib_ILI9341_18x240x320_SWSPI ucg(/*sclk=*/ 7, /*data=*/ 6, /*cd=*/ 5 , /*cs=*/ 3, /*reset=*/ 4); ) All worked on 5110 lcd. but i haven't it now. Can you help please?
ps: sorry for my english =-)
Jean-Pierre Cocatrix wrote 01/21/2018 at 13:01 point
Probably a problem of uart if nothing seems received. I don't have a prototype to test it.
koka5675766 wrote 12/09/2017 at 07:27 point
Hello. At me the offer to the author, to add the timer of inclusion and deenergizing on time.
vis22 wrote 11/01/2017 at 17:28 point
Hello, for quality sound it is important to know the level of wi-fi signal. Is there a possibility to bring the level indicator wi-fi access the management page of Karadio.
Jean-Pierre Cocatrix wrote 11/01/2017 at 18:05 point
I tried some time ago, but it broke somethings. I agree that it is a good feature. I will try again.
Done in 1.6.2
vis22 wrote 11/02/2017 at 20:35 point
Many thanks for your promptness. Updated to 1.6.2, the wi-fi indicator is working.
Thomas wrote 09/03/2017 at 12:33 point
Hi JP, i have a big problem. After upgrading from 1.1.7 to 1.6 I have no sound anymore. The slider for loudness goes from minus 127 to 0. Is there a change from a variable to a signed type? I tried to enable the patch as well but no success. Any further Idea what to try?
Thanks a lot and have a nice Sunday
Thomas
Jean-Pierre Cocatrix wrote 09/03/2017 at 13:04 point
It seems that your vs1053 doesn't like the vs patch. To disable it on the uart interface or with telnet type the command
sys.patch("0")
and reset the esp8266<
The slider in db is from -127db to 0db
Jean-Pierre Cocatrix wrote 09/03/2017 at 13:11 point
Or may be another problem on wire because it is the only cause i can imagine. See the log on the serial at the beginning to see if the vs is well detected.
Thomas wrote 09/11/2017 at 06:55 point
Hi JP, it seems to be a defect in Flash memory.
I tried several things. A reflash ended in a blinking Pattern twice a second and no serial output. So i assume the flash is dead. I replaced the ESP8266 board and now it runs good again.
Regards
Thomas
satos wrote 08/27/2017 at 13:26 point
Hi,I like your projekt very much.
Now i have a little problem with the OLED Display.
Sometimes it loses connection to ESP and the Text  becomes  static.
I use a Wemos D1 mini and the Arduino ATmega 328 mini pro 8Mhz 3.3V to
drive the OLED. I also use IR and the Switches.
When i set the uart speed again (sys.uart("28800") it works
for some time, only the displayed Ip at startup is then 0.0.0.0 But Sound is ok and the "real" IP is also reachable with the Browser.
I work with Version 1.6 and i believe it worked better with 1.4 in my Case. Any Ideas?
jan wrote 08/22/2017 at 18:04 point
Is it possible to make a soft reset from the ardruino
Jean-Pierre Cocatrix wrote 08/22/2017 at 20:08 point
from the arduino? I don't have an arduino on this project apart the addon for lcd and controls. Anyway, to send a reboot on the serial, the command is
sys.boot
ernie 881 wrote 06/09/2017 at 14:59 point
I personally think that the red VS1053B modules e. g. http://www.ebay.de/itm/VS1053-MP3-Module-with-SD-card-slot-VS1053B-Ogg-real-time-recording-for-Arduino-/272508590908?hash=item3f72c71b3c:g:1ogAAOSwUKxYa5fD are much better than the blue ones labeled "lcsoft studio" or "lc technology". These were or damaged at arrival or dead after a few hours and don't have pin 34 pulled down (mp3 enabled at startup see http://www.bajdi.com/lcsoft-vs1053-mp3-module/ ).
Jean-Pierre Cocatrix wrote 06/13/2017 at 20:19 point
I own all models lcsoft, red one and alientek (more complete than other) and all play for month now without problem.
The pin 34 is not a problem with the software patch.
ldv82 wrote 05/30/2017 at 13:44 point
Most likely, this depends on the compatibility of VS1053 and DAC. You will use an external DAC instead of the built-in VS1053.
Jean-Pierre Cocatrix wrote 05/30/2017 at 16:37 point
I am not an expert on DAC. All I know is:
##I2S speed: 0, 0=48kHz, 1=96kHz, 2=192kHz#
from the vs1053.
brony wrote 05/20/2017 at 04:53 point
Hi. Could you implement so called "radio buttons" to select preset stations?
aqvarius-sey wrote 05/18/2017 at 14:57 point
on version 1.1.5 strange problem. if you have installed memory and increase the volume of the radio goes silent. only a reboot helps. if the memory is to retrieve all works. checked all the connection is correct.
aqvarius-sey wrote 05/18/2017 at 10:05 point
hi! in the beginning I want to say thank you for a great project! I have a question to the Creator. updated from version 1.1.5 to 1.2.1. buttons connected to an analog input. problems: 1. when adjusting the volume there is no smooth adjustment while holding the button. 2. when you press short the volume randomly changes (jumps from low to high and back). in version 1.1.5 often, she cleared the EEPROM in the esp8266, you need to re-set the network settings, and list of stations.
AndrzejSc wrote 05/16/2017 at 14:32 point
I have a problem when change uart to 9600, after reset radio doesn't play. If I change back to 115200 it's play again. Debug informations is the same at both cases. Any ideas ?
ldv82 wrote 05/16/2017 at 09:44 point
What are the advantages of ESP32? Any new functions will be at the radio?
Jean-Pierre Cocatrix wrote 05/16/2017 at 09:53 point
Don't know yet ;-)
Just for fun and may be bluetooth, but I have to learn it before.
ldv82 wrote 05/15/2017 at 13:54 point
jp cocatrix
Do not plan a version STM32+SSD1306+encoder?
Jean-Pierre Cocatrix wrote 05/15/2017 at 22:32 point
Yes, i'am working on it. Some technical problem with u8glib ...
Jean-Pierre Cocatrix wrote 05/30/2017 at 16:33 point
Too busy to study the STM32. I have one but unpacked for the moment.
Roman wrote 05/13/2017 at 15:29 point
HI,Problem! Radio sometimes stops working (hangs)!!!!
Thanks
Best regards,
~~ Roman
Flex wrote 05/14/2017 at 15:04 point
Hey,
I’ve got a similar problem, sometimes stops the VS Coding and needs a reset. The NodeMCU and Website keep working well, but the speaker didn’t get a signal from the decoder. It seems to happen randomly, sometimes after 20min and othertimes the systems run over hours perfectly.
I use an NodeMCU connected to an Arduino (for the OLED and a FM transmitter), buttons and such an VS1053: http://www.ebay.de/itm/VS1053-MP3-Module-Development-Board-w-On-Board-Recording-Function-SPI-Interface-/291596880495?hash=item43e4874a6f:g:gm4AAOSwEK9Tw2qE
It could be a pointer issue of the VS, when I stream from my Shoutcast-Server with 320kbps stereo it feels like the problem comes earlier as if I stream with 98kbps mono signal.
Greets
Felix
cwojtala wrote 05/03/2017 at 11:49 point
Hi, i've got an issue. I flashed the esp8266 with the esptool like this:
esptool.py write_flash 0x000 boot_v1.6.bin 0x01000 user1.4096.new.4.bin
0x81000 user2.4096.new.4.bin 0x7e000 blank.bin 0x3fe000 blank.bin
0xfc000 esp_init_data_default.bin 0x3fc000 esp_init_data_default.bin
and it seemed to work. i can connect to the AP but when i fill in the SSID ans password an then click validate nothing happens, after a reset its still in ap mode....
pls hlp
chris
Jean-Pierre Cocatrix wrote 05/03/2017 at 13:46 point
dhcp, or ip,mask,  gateway?
In dhcp the ip may be read on the uart interface.
cwojtala wrote 05/03/2017 at 13:59 point
i.ve tried both. it starts always in ap mode again
Jean-Pierre Cocatrix wrote 05/03/2017 at 14:01 point
check with a terminal on the usb com port. You will see the error. Certainly a bad password.
cwojtala wrote 05/03/2017 at 14:51 point
dont ask m how but after a couple resets ist working now. what i observed is tha at the beginning there was no mac adress next to the wlan security options, but now is is there and its working. thx for this very cool project
Jean-Pierre Cocatrix wrote 05/03/2017 at 14:23 point
notice that the validate will reset automatically. It is the validate on right of the Wifi & Network label
Vishal Dhayalan wrote 04/22/2017 at 22:51 point
Hi again, can you also tell me which files i need to flash onto the ESP8266 NodeMCU and any other details required in this process? There seems to be more files in the 'files' section, than shown in the images on instructables for this project... Thank you.
Jean-Pierre Cocatrix wrote 05/03/2017 at 13:50 point
Which one?
Vishal Dhayalan wrote 04/22/2017 at 22:48 point
Hi, is it possible to add IR-Remote alone, without a display? and i would like it to just run on the esp8266 NodeMCU, without an arduino, as I'm trying to run on a minimum setup with basic user controls. Love all the effort and time you've put into this! Thank you.
Jean-Pierre Cocatrix wrote 05/03/2017 at 13:48 point
no, not without arduino mini pro. But you can have IR remote without display. Just don't add it.
Thanks
Paul wrote 04/14/2017 at 01:41 point
Hi, the ntp client is a fantastic new feature, for some reason the time is returning as UTC +1. When I add my tzo ("+8") the clock reads one hour ahead. I have changed my tzo to +7 to give me the correct time for now. Will you be correcting this in the future. We don't have dst where I live, so thats not the issue.
Thanks for all your hard work on this project :)
Jean-Pierre Cocatrix wrote 05/03/2017 at 13:52 point
No, it is a simplified implementation.
cwojtala wrote 04/09/2017 at 12:12 point
I'm a little  bit confusedFirst: if i connect the buttons to the adc, do i have to change the firmware in the esp8266?
And second: i've odered this Module:
VS1003B VS1053 MP3 Module Development Board Onboard recording function
 http://s.aliexpress.com/veUV3iiU
(from AliExpress Android)
Does ist work with ist? If yes, how do i connect it to the ESP Board?
Jean-Pierre Cocatrix wrote 04/09/2017 at 12:43 point
1/ No, it is auto detected in software.
2/ Not sure, it is a vs1003. Partial support only by Karadio. Some doesn't work at all.
Th wire is well noted on the board. Same as vs1053.
cwojtala wrote 04/10/2017 at 11:48 point
thanks. Knowing my luck, my board won't work. But i can tell when it arrive from china
Eugene wrote 04/18/2017 at 16:13 point
This board works correctly with this project, have the same one
