WiFi Webradio on ESP8266 or ESP32
KaRadio
A fully featured wifi web radio player with only low cost boards.
with or without a vs1053 board
Control with any browsers (ie edge, chrome mozilla etc...).
or with an external hardware panel or with the uart interface or with telnet.
Memory for 255 stations
OTA (On the Air) upgrade,
Read direct mp3 or ogg or WMA streams or playlist .pls .m3u, asx and .xspf
Read up to a 320 kb/s stream,
Encoder, IR, lcd ...
Embedded wifi configuration via the web or serial or telnet.
Metadata displayed (ie Title of the current song if given in the stream),
Permanent setting (sound setting, stations, wifi)
Server multi clients with automatic refresh (websocket),
The stations may be downloaded and uploaded within the web site,
Stations sort management by drag drop.
very quick responsive web by caching local information in the browser and websocket.
additional hardware: a led indicates the state of the equipment
Optional: control switches, lcd display, additional ram for buffering
See http://www.instructables.com/id/Wifi-Webradio-With-ESP8266-and-VS1053 for the description of the minimal prototype.
See Github for sources
See github source for the ESP32 version ( vs1053 or i2s or pcm or internal DAC)
See A project derived from KaRadio32 in progress.
See the lcd +IR software's on Github AddOn
See some realizations of users at KaraDio
A nextion touchscreen display for KaraDio from yo2ldk : Here
For more informations or questions, you can enter to the Karadio facebook group
KaRadio32 Release 1.9
KaRadio32:
Release 1.9 Rev 1 - Built on 2019/02/20
New:
  • 1.9 R1:
    • Labels in the csv hardware configuration.
    • Toggle main/time now permanent. On time display, an event go to the main screen for 3 seconds then return to time screen.
    • More reactive display on lcd.
-  Improved encoder for new chinese device (shorter pulses) (reverse A/B in case of reverse way)
-  Better vs1053 detection.
-  RSSI display needed a click of a button to start.
-  AP mode on init: the web page starts on the "Setting" panel and the stations list is skipped.
-  Wifi option: If wifi is disconnected choose to reset or wait for the connection on the same SSID:
-  Command wifi.auto("x") with x = 0: reboot, x=1: wait for the SSID
-  For internal reasons, the touch screen needs to be calibrated again.
-  No more fall back to i2s when the vs1053 is not detected. - Many small improvements in the code.
KaRadio: Release 1.8
Release 1.8 R2 - Built on 2019/02/10
New:
  • 1.8:
    • Ram optimization
    • New edit panel with play/stop control
    • New volume control on web with Ctrl arrow keys
    • New upgrade indication on telnet, serial and web
    • Web page look changed (a bit),
    • Added the TZO on the setting page
    • Added the mDNS hostname on the setting page
History:
history
For ESP32 see the github page KaRadio32. Release 1.6 R4
ESP8266 Simplest prototype:
- Optional external ram (23LCV1024) support (1:CS/=GPIO16 2:MISO=GPIO12 3:NC 4:GND 5:MOSI=GPIO13 6:SCK=GPIO14 7:GND 8:3.3v)
Attention:
The optional led is now on GPIO2. The blue led on the ESP8266 is blinking at the same rate.
GPIO16 is now the Chip select for the external ram if any.
The external ram is detected at boot time if present.
To upgrade to this release, please flash user1.4096.new.4.bin at 0x1000 ,
user2.4096.new.4.bin at 0X81000 and blank.bin at 0x7e000 & 0x3fe000
After that, all next updates are done with the On The Air (OTA) feature.
New binaries are hosted at http://karadio.karawin.fr .
Loading the esp8266
KaRadio32.bin
KaRadio32 1.9 Rev 1
octet-stream - 1.39 MB - 02/21/2019 at 13:14
Download
KaRadio 1.8 R2
octet-stream - 378.14 kB - 02/11/2019 at 14:04
Download
KaRadio 1.8 R2
Download
octet-stream - 3.98 kB - 09/17/2017 at 10:26
Download
octet-stream - 4.00 kB - 07/21/2016 at 15:19
Download
View all 6 files
View all 6 components
View all 11 project logs
  • 1
    Step 1
    Wiring:
    From ESP8266_ESP12( 3.3 v) or nodeMCU(5v) to VS1053 (5 v)
    REST:
    ADC : gound if control panel not used
    CH_PD to 3.3v
    GPIO16 led output
    D5:GPIO14 to VS1053 SCK
    D6:GPIO12 to VS1053 MISO (or so)
    D7:GPIO13 to VS1053 MOSI (or si)
    TXD to CH340G UART rx
    RXD from CH340G UART tx
    D1:GPIO05 to VS1053 XDCS
    D2:GPIO04 to VS1053 DREQ
    D3:GPIO00 to VS1053 XRST
    GPIO02
    D8:GPIO15 to VS1053 XCS
View all instructions
Zoltán Tóth wrote 01/15/2019 at 16:44 point
Hello!
I want a firmware that runs the SH1106 LED display, unfortunately I couldn't solve it ... Thank you! Sorry for my weak English knowledge! If I were to get a link it would be the simplest ... The display is 128x64 size 1.3 ".
nox.air wrote 10/16/2018 at 15:58 point
Hello Jean-Pierre and everybody!
Could you advice me? I'm trying to do KaRadio32 with the ESP32 Devkitv1, but something's wrong. I suspect "Flash download tools" can't do with my ESP properly.
First it couldn't download KaRadio32 to the ESP32 (esp_sync_blocking), but later I managed to erase (only pressing boot while ....._____....._____). Only after this I finally loaded KaRadio32 to my ESP32. I linked it to WiFi but monitoring worked during near minute and finished. Maybe the device is defected? But later I installed Mongoose OS to the ESP32. It worked and exchanged data via WiFi. I've not recieved an amplifier from Aliexpress yet, so can't test lineout.
Is there another loader for ESP32, not "Flash download tools"? And maybe I can do something else?
Thank you in advance!
makersting wrote 07/04/2018 at 12:54 point
Hello Jean-Pierre,
somehow I managed to get contact to the ESP via my mobile. When I first entered the wifi-settings, I broke up to fast: I only filled in the information for my home-ssid and its passowrd, then I accidently saved before I filled in the IP-adress of the router. Now I cant find the ESP any more in the WiFi-net. What can I do?
Thanx!
Edit: I maneged to fix the problem. Actualy it was a network problem, so it has had nothing to do with Karadio.
Thanx for the effort creating this great internet-radio, Jean-Pierre!
lellobov wrote 06/06/2018 at 13:05 point
kindly there is someone who can show me the schematic and code to used an LCD 16x2 and control with three keys. thanks
PIERRE wrote 05/24/2018 at 11:54 point
Hello, I build this project with a esp32 and all run for the best but i would like to move the VSPI pins (18/19/23/5) to the HSPI pin (12/13/14/15) for a simplification of a PCB design and  this don't run.
The web and telnet is OK, i can use the radio but nothing is display on the LCD.
(Type 197 )
I test the screen with another soft and it'ok.
I checked all the GPIO.H and all the files where SPI is called but i didn't found where i made a mistake.
Could you help me ?
Jean-Pierre Cocatrix wrote 06/23/2018 at 22:54 point
How can I?Send the gpio.h may be
Jean-Pierre Cocatrix wrote 05/06/2018 at 11:07 point
Take it at http://karadio.karawin.fr/KaRadio32.bin
Thanks, I forgot to mention it.
TheotherMike wrote 05/06/2018 at 16:44 point
Thank you so much ! Sound over vs1053 as well as I2C-OLED are running now. So nice !!
Unfortunately after some minutes it stops music an does not respond until repowering..?
Jean-Pierre Cocatrix wrote 05/06/2018 at 16:46 point
See on telnet or uart log if an error is found..
TheotherMike wrote 05/06/2018 at 17:45 point
Mmh, using telnet/uart I was able to change to the correct display, did a system reboot and an ota update...so that all works nicely.  Log does not show any errors. Log states "playing". So I tested it with vs1053 patch (what is it for?) and without...same behavior, it suddenly stops audio after some short time.
Jean-Pierre Cocatrix wrote 05/08/2018 at 09:09 point
For all url?
TheotherMike wrote 05/08/2018 at 09:48 point
"For all URL?"
Seems so. Whole yesterday evening I tested and had Trouble even with local Radio streams. Webpage and LCD still running until a station Change, then it completely hangs. I will reorder some Hardware.... Interestingly I used exactly this VS1053 with an ESP8266 and your Software without issues...
TheotherMike wrote 05/14/2018 at 19:57 point
Hah, it is working now ! It seems to be an issue with the ESP32. I used a new one and now its perfect !! Also, I think its running faster now...
Best regards,
Mike
TheotherMike wrote 05/06/2018 at 09:31 point
Dear JP,
I have an ESP32-WROOM on my desk and want to built your radio.
Unfortunately, I cannot find the "build/karadio32.bin" in your github!?
Where are the install binaries located ?
Thank you in advance,
Mike
Thomas wrote 03/21/2018 at 08:19 point
Hello JP,
are there any known stability issues in 1.6.3?
I tried to build a new  Karadio and after updating  to 1.6.3 i have bootloops.
Tried on different modules. After Reflashing back to 1.0.8 it works stable.
Any Idea?
Thanks
Thomas
Jean-Pierre Cocatrix wrote 03/21/2018 at 08:23 point
From 1.0.8 to 1.6.3, it is a big jump. I think that it will be useful to erase all the flash eprom, all 4MB.
Thomas wrote 03/21/2018 at 09:25 point
I have the binaries 1.0.8 laying around. And ever i build a new karadio i flash them and than i update via the Webinterface Update button.
But you're right. It is a big Jump. I will download new binaries from your Github, erease the whole flash and try again.
Flash Pattern is still identical?
1. Boot
2. User1
3. User2
4. blank
5. blank
6. default
7. default
Thanks
Thomas
Jean-Pierre Cocatrix wrote 03/21/2018 at 12:38 point
The saved data structure is not compatible with the old one.
<try https://github.com/TridentTD/ESP8266FactoryReset to erase all.
Kabron wrote 03/11/2018 at 07:08 point
I configured addon.h and gpio.h as following:
#define LCD_COLOR 128 //0x80
#define LCD_SPI 194 //0x40
#define LCD_I2C 0
#define LCD_NONE 255
#define PIN_LCD_CS GPIO_NUM_14 //CS
#define PIN_LCD_A0 GPIO_NUM_27 //A0 or D/C
#define PIN_LCD_RST GPIO_NUM_33 //Reset RES RST or not used`
compiled OK, stations receive OK
sys.lcd
##LCD is 194#
but after start I see very very slowly LCD filling with light blue and nothing more.
Jean-Pierre Cocatrix wrote 03/11/2018 at 08:35 point
Your mistake is on addon.h. It must not be changed.
#define LCD_SPI            64 //0x40
The lcd type is set by sys.lcd command.
Kabron wrote 03/11/2018 at 10:57 point
Thank you for fast reaction.
I corrected it with no result. Additional test results I putted on github page.
Slovator wrote 03/03/2018 at 15:17 point
Is it possible to add a radio on / off function at the specified time in the project on ESP32?
wlads wrote 02/24/2018 at 13:34 point
Thank you for the project.
I do not have enough cyrillic fonts, please add
pilnikov wrote 02/06/2018 at 14:51 point
Hello JeanPierre. Thank you very much for your great useful work for us. I want to modify my radio (add the WEB function to it) So I had an little idea about it, maybe she is not new, of course, but I decided to share it with you. My radio on the side can play files from USB, Micro SD, Bluetooth and AUX. Also my radio have a Ir RC. Aliexpress sells many similar low cost modules.  The idea of controlling my radio by 1 wire (through Ir line) - by small means we get more opportunities.
How do you like this?
mauro.venturelli wrote 01/21/2018 at 11:10 point
Hello JeanPierre, first of all ,thanks for the beautiful project.
I've built one (KaRadio-32 with integrated addons) and an LCD ILI9341 194 // 240x320
Everything working fine but the image is shifted to right by abt 20 pixels,any possibility of fixing it ?
Thanks
Mauro
Jean-Pierre Cocatrix wrote 01/21/2018 at 12:57 point
Look at the lcd switched off. You will see that it is the lcd itself with a black array on left.
petitjp wrote 01/18/2018 at 20:35 point
bonjour Jean-Pierre
Je m'appelle aussi Jean-Pierre : j'ai 66 ans et j'aurai besoin de votre aide pour adapter votre système pour ma mère de 86 ans... elle écoute France Inter en WiFi mais elle devient très maladroite...je vous dis quoi (je suis chti) par Mel : mode Ip. Merci
Eugene wrote 12/21/2017 at 14:18 point
Hello Jean-Pierre, thank you very much for your wonderfull project. I have some problem with lcd display ( ili9341) initialization . I can see just:
Karadio
(c) Karawin
IR+clcd V1.1
IP:
and nothing more. I use arduino pro mini + lcd ili 9341 + karadioUCglib. Uart speed 28800 same on arduino and esp 12f. (ucglibConf: Ucglib_ILI9341_18x240x320_SWSPI ucg(/*sclk=*/ 7, /*data=*/ 6, /*cd=*/ 5 , /*cs=*/ 3, /*reset=*/ 4); ) All worked on 5110 lcd. but i haven't it now. Can you help please?
ps: sorry for my english =-)
Jean-Pierre Cocatrix wrote 01/21/2018 at 13:01 point
Probably a problem of uart if nothing seems received. I don't have a prototype to test it.
koka5675766 wrote 12/09/2017 at 07:27 point
Hello. At me the offer to the author, to add the timer of inclusion and deenergizing on time.
vis22 wrote 11/01/2017 at 17:28 point
Hello, for quality sound it is important to know the level of wi-fi signal. Is there a possibility to bring the level indicator wi-fi access the management page of Karadio.
Jean-Pierre Cocatrix wrote 11/01/2017 at 18:05 point
I tried some time ago, but it broke somethings. I agree that it is a good feature. I will try again.
Done in 1.6.2
vis22 wrote 11/02/2017 at 20:35 point
Many thanks for your promptness. Updated to 1.6.2, the wi-fi indicator is working.
Thomas wrote 09/03/2017 at 12:33 point
Hi JP, i have a big problem. After upgrading from 1.1.7 to 1.6 I have no sound anymore. The slider for loudness goes from minus 127 to 0. Is there a change from a variable to a signed type? I tried to enable the patch as well but no success. Any further Idea what to try?
Thanks a lot and have a nice Sunday
Thomas
Jean-Pierre Cocatrix wrote 09/03/2017 at 13:04 point
It seems that your vs1053 doesn't like the vs patch. To disable it on the uart interface or with telnet type the command
sys.patch("0")
and reset the esp8266<
The slider in db is from -127db to 0db
Jean-Pierre Cocatrix wrote 09/03/2017 at 13:11 point
Or may be another problem on wire because it is the only cause i can imagine. See the log on the serial at the beginning to see if the vs is well detected.
Thomas wrote 09/11/2017 at 06:55 point
Hi JP, it seems to be a defect in Flash memory.
I tried several things. A reflash ended in a blinking Pattern twice a second and no serial output. So i assume the flash is dead. I replaced the ESP8266 board and now it runs good again.
Regards
Thomas
satos wrote 08/27/2017 at 13:26 point
Hi,I like your projekt very much.
Now i have a little problem with the OLED Display.
Sometimes it loses connection to ESP and the Text  becomes  static.
I use a Wemos D1 mini and the Arduino ATmega 328 mini pro 8Mhz 3.3V to
drive the OLED. I also use IR and the Switches.
When i set the uart speed again (sys.uart("28800") it works
for some time, only the displayed Ip at startup is then 0.0.0.0 But Sound is ok and the "real" IP is also reachable with the Browser.
I work with Version 1.6 and i believe it worked better with 1.4 in my Case. Any Ideas?
jan wrote 08/22/2017 at 18:04 point
Is it possible to make a soft reset from the ardruino
Jean-Pierre Cocatrix wrote 08/22/2017 at 20:08 point
from the arduino? I don't have an arduino on this project apart the addon for lcd and controls. Anyway, to send a reboot on the serial, the command is
sys.boot
