close-circle
WiFi Webradio with ESP8266 and VS1053
A wifi web radio player with only low costs boards.
KaRadio, listen the world.
close
Control with any browsers (ie edge, chrome mozilla etc...).
or with an external hardware panel or with the uart interface or with telnet.
Memory for 255 stations
OTA (On the Air) upgrade,
Read direct mp3 or ogg or WMA streams or playlist .pls .m3u, asx and .xspf
Read up to a 320 kb/s stream,
Embedded wifi configuration via the web or serial or telnet.
Metadata displayed (ie Title of the current song if given in the stream),
Permanent setting (sound setting, stations, wifi)
Server multi clients with automatic refresh (websocket),
The stations may be downloaded and uploaded within the web site,
Stations sort management by drag drop.
very quick responsive web by caching local information in the browser and websocket.
additional hardware: a led indicates the state of the equipment
Optional: control switches, lcd display, additional ram for buffering
See http://www.instructables.com/id/Wifi-Webradio-With-ESP8266-and-VS1053 for the description of the minimal prototype.
See Github for sources
See the lcd +IR software's on Github AddOn
See some realizations of users at KaraDio
A nice telnet+IR extension from Gábriel Kovács gabeszakem@gmail.com: ESP8266-WiFi-UART-Bridge-master.zip
A nextion touchscreen display for KaraDio from yo2ldk : Here
For more informations or questions, you can enter to the Karadio facebook group
Release 1.6.1
Built on 2017/09/17
New:
  • 1.6.1: Click on header to rewind to the top of a page.
  • Header stays on top of the web page
  • gzipped html tranfert. More stable and improved speed
  • The page content follows the header size.
History:
history
Simplest prototype:
- Optional external ram (23LCV1024) support (1:CS/=GPIO16 2:MISO=GPIO12 3:NC 4:GND 5:MOSI=GPIO13 6:SCK=GPIO14 7:GND 8:3.3v)
Attention:
The optional led is now on GPIO2. The blue led on the ESP8266 is blinking at the same rate.
GPIO16 is now the Chip select for the external ram if any.
The external ram is detected at boot time if present.
To upgrade to this release, please flash user1.4096.new.4.bin at 0x1000 ,
user2.4096.new.4.bin at 0X81000 and blank.bin at 0x7e000 & 0x3fe000
After that, all next updates are done with the On The Air (OTA) feature.
New binaries are hosted at http://karadio.karawin.fr .
Loading the esp8266
First use
  • If the access point of your router is not known, the webradio initializes itself as an AP. Connect your wifi to the ssid "WifiWebRadio",
  • Browse to 192.164.4.1 to display the page, got to "setting" "Wifi" and configure your ssid ap, the password if any, the wanted IP or use dhcp if you know how to retrieve the dhcp given ip (terminal or scan of the network).
  • In the gateway field, enter the ip address of your router.
  • Validate. The equipment restart to the new configuration. Connect your wifi to your AP and browse to the ip given in configuration.
  • Congratulation, you can edit your own station list. Don't forget to save your stations list in case of problem or for new equipments.
  • if the AP is already know by the esp8266, the default ip at the first start is 192.168.1.254
  • a sample of stations list is on https://github.com/karawin/Ka-Radio/blob/master/ESP8266-Firmware/WebStations.txt . Can be uploaded via the web page.
Feedback
Please tell me if you succeeded or something more can be done, thanks.
The second step will add some hardware buttons (vol + -, station + -, play ...)
Wiring:
From ESP8266_ESP12( 3.3 v) or nodeMCU(5v) to VS1053 (5 v)
REST
ADC
CH_PD to 3.3v
GPIO16 (a 1Hz output)
D5:GPIO14 to VS1053 SCK
D6:GPIO12 to VS1053 MISO
D7:GPIO13 to VS1053 MOSI
TXD to CH340G UART rx
RXD from CH340G UART tx
D1:GPIO05 to VS1053 XDCS
D2:GPIO04 to VS1053 DREQ
D3:GPIO00 to VS1053 XRST
GPIO02
D8:GPIO15 to VS1053 XCS
octet-stream - 368.13 kB - 09/17/2017 at 10:26
download-circle
Download
download-circle
Download
octet-stream - 3.98 kB - 09/17/2017 at 10:26
download-circle
Download
octet-stream - 4.00 kB - 07/21/2016 at 15:19
download-circle
Download
esp_init_data_default.bin
Must be written only one time.
octet-stream - 128.00 bytes - 07/21/2016 at 15:18
download-circle
Download
View all 6 components
View all 11 project logs
  • 1
    Step 1
    Wiring:
    REST:
    ADC : gound if control panel not used
    CH_PD to 3.3v
    GPIO16 led output
    D6:GPIO12 to VS1053 MISO (or so)
    D7:GPIO13 to VS1053 MOSI (or si)
    GPIO02
  • 2
    Step 2
View all instructions
Thomas wrote 09/03/2017 at 12:33 point
Hi JP, i have a big problem. After upgrading from 1.1.7 to 1.6 I have no sound anymore. The slider for loudness goes from minus 127 to 0. Is there a change from a variable to a signed type? I tried to enable the patch as well but no success. Any further Idea what to try?
Thanks a lot and have a nice Sunday
Thomas
jp cocatrix wrote 09/03/2017 at 13:04 point
It seems that your vs1053 doesn't like the vs patch. To disable it on the uart interface or with telnet type the command
sys.patch("0")
and reset the esp8266<
The slider in db is from -127db to 0db
jp cocatrix wrote 09/03/2017 at 13:11 point
Or may be another problem on wire because it is the only cause i can imagine. See the log on the serial at the beginning to see if the vs is well detected.
Thomas wrote 09/11/2017 at 06:55 point
Hi JP, it seems to be a defect in Flash memory.
I tried several things. A reflash ended in a blinking Pattern twice a second and no serial output. So i assume the flash is dead. I replaced the ESP8266 board and now it runs good again.
Regards
Thomas
satos wrote 08/27/2017 at 13:26 point
Hi,I like your projekt very much.
Now i have a little problem with the OLED Display.
Sometimes it loses connection to ESP and the Text  becomes  static.
I use a Wemos D1 mini and the Arduino ATmega 328 mini pro 8Mhz 3.3V to
drive the OLED. I also use IR and the Switches.
When i set the uart speed again (sys.uart("28800") it works
for some time, only the displayed Ip at startup is then 0.0.0.0 But Sound is ok and the "real" IP is also reachable with the Browser.
I work with Version 1.6 and i believe it worked better with 1.4 in my Case. Any Ideas?
jan wrote 08/22/2017 at 18:04 point
Is it possible to make a soft reset from the ardruino
jp cocatrix wrote 08/22/2017 at 20:08 point
from the arduino? I don't have an arduino on this project apart the addon for lcd and controls. Anyway, to send a reboot on the serial, the command is
sys.boot
ernie 881 wrote 06/09/2017 at 14:59 point
I personally think that the red VS1053B modules e. g. http://www.ebay.de/itm/VS1053-MP3-Module-with-SD-card-slot-VS1053B-Ogg-real-time-recording-for-Arduino-/272508590908?hash=item3f72c71b3c:g:1ogAAOSwUKxYa5fD are much better than the blue ones labeled "lcsoft studio" or "lc technology". These were or damaged at arrival or dead after a few hours and don't have pin 34 pulled down (mp3 enabled at startup see http://www.bajdi.com/lcsoft-vs1053-mp3-module/ ).
jp cocatrix wrote 06/13/2017 at 20:19 point
I own all models lcsoft, red one and alientek (more complete than other) and all play for month now without problem.
The pin 34 is not a problem with the software patch.
ldv82 wrote 05/30/2017 at 13:44 point
Most likely, this depends on the compatibility of VS1053 and DAC. You will use an external DAC instead of the built-in VS1053.
jp cocatrix wrote 05/30/2017 at 16:37 point
I am not an expert on DAC. All I know is:
##I2S speed: 0, 0=48kHz, 1=96kHz, 2=192kHz#
from the vs1053.
brony wrote 05/20/2017 at 04:53 point
Hi. Could you implement so called "radio buttons" to select preset stations?
aqvarius-sey wrote 05/18/2017 at 14:57 point
on version 1.1.5 strange problem. if you have installed memory and increase the volume of the radio goes silent. only a reboot helps. if the memory is to retrieve all works. checked all the connection is correct.
aqvarius-sey wrote 05/18/2017 at 10:05 point
hi! in the beginning I want to say thank you for a great project! I have a question to the Creator. updated from version 1.1.5 to 1.2.1. buttons connected to an analog input. problems: 1. when adjusting the volume there is no smooth adjustment while holding the button. 2. when you press short the volume randomly changes (jumps from low to high and back). in version 1.1.5 often, she cleared the EEPROM in the esp8266, you need to re-set the network settings, and list of stations.
AndrzejSc wrote 05/16/2017 at 14:32 point
I have a problem when change uart to 9600, after reset radio doesn't play. If I change back to 115200 it's play again. Debug informations is the same at both cases. Any ideas ?
ldv82 wrote 05/16/2017 at 09:44 point
What are the advantages of ESP32? Any new functions will be at the radio?
jp cocatrix wrote 05/16/2017 at 09:53 point
Don't know yet ;-)
Just for fun and may be bluetooth, but I have to learn it before.
ldv82 wrote 05/15/2017 at 13:54 point
jp cocatrix
Do not plan a version STM32+SSD1306+encoder?
jp cocatrix wrote 05/15/2017 at 22:32 point
Yes, i'am working on it. Some technical problem with u8glib ...
jp cocatrix wrote 05/30/2017 at 16:33 point
Too busy to study the STM32. I have one but unpacked for the moment.
Roman wrote 05/13/2017 at 15:29 point
HI,Problem! Radio sometimes stops working (hangs)!!!!
Thanks
Best regards,
~~ Roman
Flex wrote 05/14/2017 at 15:04 point
Hey,
I’ve got a similar problem, sometimes stops the VS Coding and needs a reset. The NodeMCU and Website keep working well, but the speaker didn’t get a signal from the decoder. It seems to happen randomly, sometimes after 20min and othertimes the systems run over hours perfectly.
I use an NodeMCU connected to an Arduino (for the OLED and a FM transmitter), buttons and such an VS1053: http://www.ebay.de/itm/VS1053-MP3-Module-Development-Board-w-On-Board-Recording-Function-SPI-Interface-/291596880495?hash=item43e4874a6f:g:gm4AAOSwEK9Tw2qE
It could be a pointer issue of the VS, when I stream from my Shoutcast-Server with 320kbps stereo it feels like the problem comes earlier as if I stream with 98kbps mono signal.
Greets
Felix
cwojtala wrote 05/03/2017 at 11:49 point
Hi, i've got an issue. I flashed the esp8266 with the esptool like this:
esptool.py write_flash 0x000 boot_v1.6.bin 0x01000 user1.4096.new.4.bin
0x81000 user2.4096.new.4.bin 0x7e000 blank.bin 0x3fe000 blank.bin
0xfc000 esp_init_data_default.bin 0x3fc000 esp_init_data_default.bin
and it seemed to work. i can connect to the AP but when i fill in the SSID ans password an then click validate nothing happens, after a reset its still in ap mode....
pls hlp
chris
jp cocatrix wrote 05/03/2017 at 13:46 point
dhcp, or ip,mask,  gateway?
In dhcp the ip may be read on the uart interface.
cwojtala wrote 05/03/2017 at 13:59 point
i.ve tried both. it starts always in ap mode again
jp cocatrix wrote 05/03/2017 at 14:01 point
check with a terminal on the usb com port. You will see the error. Certainly a bad password.
cwojtala wrote 05/03/2017 at 14:51 point
dont ask m how but after a couple resets ist working now. what i observed is tha at the beginning there was no mac adress next to the wlan security options, but now is is there and its working. thx for this very cool project
jp cocatrix wrote 05/03/2017 at 14:23 point
notice that the validate will reset automatically. It is the validate on right of the Wifi & Network label
Vishal Dhayalan wrote 04/22/2017 at 22:51 point
Hi again, can you also tell me which files i need to flash onto the ESP8266 NodeMCU and any other details required in this process? There seems to be more files in the 'files' section, than shown in the images on instructables for this project... Thank you.
jp cocatrix wrote 05/03/2017 at 13:50 point
Which one?
Vishal Dhayalan wrote 04/22/2017 at 22:48 point
Hi, is it possible to add IR-Remote alone, without a display? and i would like it to just run on the esp8266 NodeMCU, without an arduino, as I'm trying to run on a minimum setup with basic user controls. Love all the effort and time you've put into this! Thank you.
jp cocatrix wrote 05/03/2017 at 13:48 point
no, not without arduino mini pro. But you can have IR remote without display. Just don't add it.
Thanks
Paul wrote 04/14/2017 at 01:41 point
Hi, the ntp client is a fantastic new feature, for some reason the time is returning as UTC +1. When I add my tzo ("+8") the clock reads one hour ahead. I have changed my tzo to +7 to give me the correct time for now. Will you be correcting this in the future. We don't have dst where I live, so thats not the issue.
Thanks for all your hard work on this project :)
jp cocatrix wrote 05/03/2017 at 13:52 point
No, it is a simplified implementation.
cwojtala wrote 04/09/2017 at 12:12 point
I'm a little  bit confusedFirst: if i connect the buttons to the adc, do i have to change the firmware in the esp8266?
And second: i've odered this Module:
VS1003B VS1053 MP3 Module Development Board Onboard recording function
 http://s.aliexpress.com/veUV3iiU
(from AliExpress Android)
Does ist work with ist? If yes, how do i connect it to the ESP Board?
jp cocatrix wrote 04/09/2017 at 12:43 point
1/ No, it is auto detected in software.
2/ Not sure, it is a vs1003. Partial support only by Karadio. Some doesn't work at all.
Th wire is well noted on the board. Same as vs1053.
cwojtala wrote 04/10/2017 at 11:48 point
thanks. Knowing my luck, my board won't work. But i can tell when it arrive from china
Eugene wrote 04/18/2017 at 16:13 point
This board works correctly with this project, have the same one
fjs1 wrote 04/04/2017 at 12:47 point
A really fantastic piece of work !  It works better than all IP radios (commercial) I had before.
Congratulations et Merci !
Franz
jp cocatrix wrote 04/04/2017 at 12:50 point
Thanks.
Yes, a bit hard to code but so exciting...
vanilinman wrote 04/01/2017 at 23:01 point
I solved the problem of crackles.I shorten the loop of wires between the modules (I connected without a breadboard).Thanks for the tips.
vanilinman wrote 04/01/2017 at 21:48 point
Thank you. You are super. It began to play. Please tell me how to get rid of crackles in the headphones. I tried various sources of power, it does not help.
jp cocatrix wrote 04/01/2017 at 21:52 point
I don't have this problem.
Check the ground wires (try another gnd entry may be) and try to short it (and all other....
Enjoy.
JP
