New Keyboard Test
A project log for NanoEgg Music Synthesizer
A powerful little music synthesizer with a classic look!
t-b-trzepaczT. B. Trzepacz 08/11/2016 at 01:570 Comments
So, I made a test print of the new keyboard model I made in Autodesk Fusion 360 the other day. In case you didn't read the last post, it looked kinda like this:
It took a few tries to get a reasonable 3d model out of the Rostock printers. It didn't like some text I had placed on the bottom of a few small parts, and I had set the resolution fairly high, so the extruder would sometimes clip the model and move bits around. 3d printing kinda sucks.
But after a couple of tries I had to leave the office, so I just let it go, and it came up with passable prints in the morning!
There were some strange artifacts, tho.
Some sort of "ghost wind"?
As always, I made separate models for white keys and black keys. The black keys had to be split into two parts because there needs to be a flat surface somewhere for 3d printing, so there is a top and bottom for each black key. I also added some parts to act as "cookies" or joiners to hold the two halves together. I had hoped for a friction fit, but it did not quite turn out that way, so I had to glue them.
The white keys could be printed as a single solid.
I added some cookies to hold the black and white key sections together too.
And I wrapped the whole thing in rubber bands to keep tension while the glue dried.
Already, I've found a number of things to fix, so chances are this print won't actually end up in a prototype, but it does help to check the scale of things.
Speaking of which., I was tired of having so much trouble with not having a good throw on the keys, I decided to disassemble a stack of toy keyboards and take down some metrics. Hopefully this helps me make something that it actually playable.
More to come!
