ODrive v3.3
A project log for ODrive - High performance motor control
Hobby brushless motors are incredibly cheap and powerful. However we need a way to make robots out of them. ODrive is that way.
oskar-weiglOskar Weigl 06/17/2017 at 20:050 Comments
v3.2 ODrives sold out very quickly. I was not planning on manufacturing a new batch until the firmware alpha is over. However, demand for alpha stage hardware has been so high, I decided to do another batch while still in alpha.
The new boards are expected to arrive in mid July. If you want to be notified as soon as they are available, you can sign up here.
I took the opportunity to sneak in a couple of minor hardware changes. Below are the changes made, straight from the CHANGELOG:
The most significant change is the GPIO Pinout change. This brings about the following possibilities over v3.2:
