Replacing lazy Susan with thrust washer
A project log for Open LIDAR
This project is to build a motorized gimbal mount to convert a laser distance module into a 3d LIDAR.
caveradamcaver.adam 07/18/2016 at 13:040 Comments
I had too many problems aligning the lazy Susan so I decided to try a thrust washer and dual set screws on the shaft. Seems to work so far.
