Lesson: headers are not secure
A project log for Open LIDAR
This project is to build a motorized gimbal mount to convert a laser distance module into a 3d LIDAR.
caveradamcaver.adam 10/09/2016 at 19:410 Comments
I've been working to recover from accidentally pulling my Arduino out of the female header pins. Since it reconnected when it landed and burned itself up...it also burned up a number of other components. I've replaced the motor drivers, the 5V regulator and the Arduino. Next I need to replace the microSD module which also burned out. Also, the serial portion of the SF30 was damaged, but the USB side still works. So I can either switch to the LidarLite 3 which has arrived now, or I can get a usb to serial module to put between the SF30 and the Arduino (I'll eventually do both so I can compare the two sensors). I'll probably work on the LidarLite portion while I wait for a USB module to come.
That being said...It took all of 2 seconds to accidentally yank that cable, but it will take 2 weeks to repair the damage. I had used headers to try to make it easier to switch parts and to prototype...but that seriously backfired here.
