Ready for Launch
A project log for Guided Rocket
I will be attempting to build a guided rocket using of the shelf parts
sagarSagar • 06/23/2014 at 23:10•2 Comments
Upon the completion of the thrust vectoring chassis, I made a body out of thin wall fiberglass. This rocket has no fins due because the test code pasted in the description will make the rocket self stabilize, if the rocket stays pointed up during the flight, we will know that our thrust vectoring system works.
Steve Shaffer wrote 06/27/2014 at 11:37 • point
I want to see this too!!! Make sure to have at least two cameras recording!
zakqwy wrote 06/23/2014 at 23:53 • point
Looks like an exciting day coming up! When will you be launching the rocket? How does it stack up: center of gravity vs center of pressure, total mass, response speed of the servos, etc? How do you plan to recover the rocket?
