1Step 1
Using the custom made CAD file of the thrust vectoring chassis, laser cut the parts out of the aluminum billet.
2Step 2
Drill 3mm holes in the necessary spots
Screws ready for mounting
Outer ring will be attached to this pivot
3Step 3
Test the fitting for the outer ring to the main frame and sand if needed, it should be a solid fit. Do the same for the inner ring, it should look like the picture below. (1 ring should turn in the x axis and the other in the y)
4Step 4
Buy and place metal gear servos in the main frame and epoxy the tabs. Next attach 1 rod to each ring, and to each servo so that the rotation of the servo changes the angle of the ring
5Step 5
Using the diagram, make a power distribution board for the servos
This is roughly what it should look like![]()
Sagar
I want to start building a rocket like that. Do you have any idea of how much will it cost?
