Lasercut Aluminum Frame!
A project log for Guided Rocket
I will be attempting to build a guided rocket using of the shelf parts
sagarSagar 06/20/2014 at 20:400 Comments
After the failure of the wood frame, a local machine shop made me a .25 inch thick aluminum frame! This frame was later tapped and threaded by me so that the gimbal can fit in it. After the parts were fitted, red permanent locktite was used to make sure they never come off during flight. Along with this, a plywood electronics bay was also laser cut.
