Endplate_B.pdfThis endplate was modified to allow us to mount the VGA output from the SBC and to have some USB ports.Adobe Portable Document Format - 31.17 kB - 10/10/2016 at 06:03 |
Endplate_A.pdfThis is a drawing of one of the endplates for the chassis. It doesn't need modificationAdobe Portable Document Format - 73.02 kB - 10/10/2016 at 05:56 |
Chassis.pdfThis is the original drawing of the chassis before we modified it to lighten it. Feel free to print it in light weight plastic!Adobe Portable Document Format - 120.39 kB - 10/10/2016 at 05:56 |
Lid.pdfThis is the original drawing for the lid before we modify it for the SBC.Adobe Portable Document Format - 84.02 kB - 10/10/2016 at 05:56 |
Bakman_THz_Review.pdfThis pdf is an overview of how a THz photomixing system works. It explains coherent detection and how two semiconductor lasers and two semiconductor mixers can be used to generate and detect THz radiation.Adobe Portable Document Format - 1.09 MB - 06/15/2016 at 19:16 |
Drone Adapter Plate - Cropped.pdfTwo of these plates will be used to attach the PB7220 to the DJI-S1000. We will fabricate them from aluminum.Adobe Portable Document Format - 84.63 kB - 05/29/2016 at 20:49 |
Chassis_edit.pdfThe chassis was modified to reduce weight. Sections that weren't required were removed as per the drawing.Adobe Portable Document Format - 173.67 kB - 05/28/2016 at 21:52 |
JoeDemersPart1.PDFA square hole for the SBC heatsink was cut into the lid and mounting holes were added.Adobe Portable Document Format - 18.71 kB - 05/28/2016 at 21:49 |
