Research
A project log for RF Mesh Network
High-throughput zero topology configuration mesh network for temporary/emergency communications over long distances.
TrademarkTrademark 06/15/2016 at 21:320 Comments
I'm doing tons of research on RF protocols. The nRF24L01+ actually uses some pretty complicated protocols. It appears that the packet structure of the real protocol does not quite match the structure of the packet object in the simulator. Perhaps I'll need to all the mapping data inside the payload of the real packet. Alas, the protocol is developed. It is just the mapping that remains. I am still working through node addressing. That stuff is complicated.
