Test fit - Corner brackets
A project log for KOSSEL XXL
I wanted to build a large printer capable of printing PLA or ABS to a high quality, speed is also of major importance. (Mini Kossel based)
aaron-dominic-richmondAaron Dominic Richmond 05/10/2016 at 11:560 Comments
All the extrusion arrived really well cut, nice clean cuts with a good accuracy. motedis.co.uk is the place to go for resonably priced extrusion cut to length in the UK.
Base placed together to check fitment.
Motors are mounted with some m3 10mm cap screws with some rubberised ESD mat in between the corners and the motors. I hope to dampen motor vibrations, this should do the same job as the laser cut cork bits you can buy on ebay.
