External connectors
A project log for KOSSEL XXL
I wanted to build a large printer capable of printing PLA or ABS to a high quality, speed is also of major importance. (Mini Kossel based)
aaron-dominic-richmondAaron Dominic Richmond 05/10/2016 at 12:160 Comments
For the print bed i am going to use a mains 240V heated bed, the switching will be done through an SSR (solid state relay). But i will need a place to plug the power in, a switch and a fuse for a bit of safety.
Using my drill and some files i managed to fit all 3 nicely together.
The back of the first one i mounted, not bad for some filework.
