Install some components
A project log for KOSSEL XXL
I wanted to build a large printer capable of printing PLA or ABS to a high quality, speed is also of major importance. (Mini Kossel based)
aaron-dominic-richmondAaron Dominic Richmond 05/11/2016 at 16:250 Comments
Mounted some of the electronics into the base of the printer, there is not much room for that PSU but it does fit.
Need to source some tie wrap bases to route all the wiring nice and neatly, using this layout I should be able to keep all the mains wiring far away from the stepper wires and limit switches.
