Tie rods
A project log for KOSSEL XXL
I wanted to build a large printer capable of printing PLA or ABS to a high quality, speed is also of major importance. (Mini Kossel based)
Aaron Dominic RichmondAaron Dominic Richmond 05/23/2016 at 12:120 Comments
The tie rods that link the effector onto the carriages need to be fairly accurate in length, i knocked up a simple jig for this using a bit of timber.
I used a drill press to put some straight 2.5mm holes in the wood and wound some m3 screws with a nice 3mm OD shank on them, probably a bit ott but it keeps my sanity in check. :)
