The main parts of the Hydroponic System include:
a. Seed feed hopper
b. Food-grade perforated conveyor system
c. Micro-irrigation system
a. Seed feed hopper
- contains and gravity feeds seed onto conveyor
- levels off seed to 2 or 3 grain depth
- can mount to the exterior if desired
b. Conveyor system
- perforations too small for seed but allow water to pass through
- if there are problems with retaining water or jamming seed, a larger perforation in the hard part of the conveyor can be covered with landscape fabric
- motorized with slow moving motor system to move at a rate of about an inch per day
- a series of stationary overhead micro-irrigation emitters that spray fish-fertilized water to supply the plants nutrient and hydration requirements
- mist emitters for germination and sprout stages
- spray emitter output increases with plant size
- requires particulate filtration of fish water
- also requires a small pump
- can consider an ebb-and-flow system for larger plants to reduce foiliar disease vectoring
ken.do
