Aquaculture System
A project log for Containerized Hydro/Aquaculture Food Production
Packed into a 20 ft. shipping container, this food production system combines automation, hydroponics and aquaculture.
kendoken.do 05/17/2016 at 18:300 Comments
The Aquaculture Aspect of this project is a little more complicated and made up of several parts:
a. Tanks, some are large and some are small
b. Fish transfer mechanization
c. Circulation system
d. Aeration system
e. Filtration system
f. Breedery/hatchery
g. Feeding system
a. Tanks
- 2 Large (400 gal), 2 medium (200 gal), and 4 small (50 gal) main tanks for growing out the fingerlings to harvest size
- Micro tanks for breeding and up to fingerling sizes
- Separate tanks could be partitioned from a larger tank
b. Fish transfer
- Mechanism for automated transfer of fish based on size
- Could be as simple as sized openings or as complex as a mechanized scooping basket
c. Circulation
- standard pumps
d. Aeration
- air inclusion occurs when the irrigation flow-through drops into the tank
- additional aeration may be required through traditional bubblers
e. Filtration
- sized grates at the bottom of tanks allow refuse to drop through
- pumped to holding tank and allowed to breakdown a little
- passed through progressively smaller mesh filters (that allow flushing)
- pH adjustments as needed before recirculated or sent to irrigate
- part of the tank system, the flow-through filter or grating allows for separation of adults and frys
- water flow pushes frys out of hatchery tank into next stage
g. Feeding system
- as the conveyor moves, bits and pieces fall through (either from the growing surface or from the return conveyor)
- algae will grow inside tanks and provide some nutrition
- additional feeding can include table scraps and other wastes
- can be supplemented by hydroponic plant matter production
